crx h22a
Old Nov 25, 2010 | 03:55 PM
teamredline9k's Avatar
Default crx h22a
im am currently doing an h swap and i am making my own mounts. i have it lined up to where i think it should be im just wondering how the axle alignment is supposed to be. with the car on the ground if you look through the spindle the intermediate shaft is about 2 1/2 inches towards the front on both sides. i dont want to make mounts and have the axle bind up. if anyone has any pics or measurements of how it is supposed to be that would be great thanks! i might be able to post pics or send them if anyone can help
Old Nov 25, 2010 | 03:59 PM
hatchet_honda's Avatar
Default Re: crx h22a
making your mounts? thats quite a challenge good luck. id just buy the swap mounts. thats what most ppl usually do, dunno if anyone here has actually welded up their own swap. i sold my h22a4 cause i couldnt find an h trans and that damn h2b plate is like 900 bucks. ehh ill boost my B lol
Old Nov 25, 2010 | 04:12 PM
yes im attempting to fab my own i have it in the car with some mock up mounts that i can sort of shim to get it set where i like.
Old Nov 26, 2010 | 08:57 AM
i hope the pics work
Old Nov 30, 2010 | 10:53 AM
ok im going to make a list of everything money wise to keep track and to share with everyone
driver side axle for 89 teg 40$
intermetiate shaft and shift linkage and assembly 50$
crx shell 500$
h22a from hmotorsonline from a freinds car i installed about 3 years ago compression good across the board 230 on all car and engine 450$ and traded shell for a tool box
need pass axle from raxles seen it for under 200$
custom mounts just takes time**
cant think of anything else at the moment ill keep you posted
Old Nov 30, 2010 | 03:18 PM
Eclectia's Avatar
It looks like you need to tilt the motor back a bit and move it up some. I'm not really sure, but i will try to take some pictures of my H22 Ef in the next few days if you can't find anything out.
Old Nov 30, 2010 | 04:22 PM
thank you that would be alot of help iv looked at all the photos i can but different mounts are in different places ya know.. what mounts and axles are you using just curious?
**just got my crank pulley machined for an 18 pack. so i guess 20$
Old Dec 24, 2010 | 03:21 PM
ok i got my raxles axle from marty great guy helped out alot and got my mounts made up ill post pics when i get time thanks to Eclectia for helping me out
picked up wet nitrous kit -200$
need to get shifter stuff mounted and and fuel need a walbro pump if anyone has one?
merry christmas everyone!
Old Dec 25, 2010 | 09:26 AM
Old Jan 4, 2011 | 03:17 PM
ordered my esp traction bar/crossmember $320 shipped
need cable to hydro conversion if anyone has one or might make one? has anyone used the ebay style one? i may get it and use some parts to make my own that i know wont break...
Old Jan 5, 2011 | 07:27 PM
oh and i used hasport mount inserts from a sponser on ht for 25$ for a 3 sets worked better than i dreamed!
Old Jan 5, 2011 | 07:55 PM
dynamoracing87's Avatar
I also have the ESP traction bar, I used his complete mount kit also. just gotta put the motor in now haha
sanchoem1's Avatar
Great job on fabricating your own mounts! I love to see people use their head instead of their wallet. Are you planning on road racing it?
Old Jan 6, 2011 | 10:52 AM
thanks for the complement! and it may be just a track car yes just kinda going with the flow now to get it up and runnin!
Old Jan 11, 2011 | 01:43 PM
Phantom240's Avatar
I wanna sacrifice my Prelude to put it's powerplant into my CRX, but then again... I dunno.
Why is it that you didn't get mounts from ESP?
Old Jan 11, 2011 | 03:17 PM
i was going to get mounts from them and i still would have if i failed at trying to build my own and they turned out pretty good i think so saved me 500 bucks is a plus!
Old Mar 1, 2011 | 05:57 PM
finally got my esp traction bar after 6+ weeks if anyone has a fuel line from the fuel rail to the filter let me know and ill take it off your hands!
Old Mar 1, 2011 | 06:06 PM
mr.dsm's Avatar
i love the hands on work!
Old Mar 1, 2011 | 06:31 PM
thanks man ill try to get pics up soon
Old Mar 1, 2011 | 06:57 PM
Valkin's Avatar
what tranny is used in your h22a build? and cable to hydro is an interesting topic would like to do the same.
Old Mar 6, 2011 | 01:36 PM
im using an h series tranny and got done today doing a mock up for the cable to hydro conversion looks pretty ghetto right now but the concept is pretty simple need to get it just right before i make my final pieces together.
Old Mar 16, 2011 | 08:32 PM
thanks to fellow ht member have ecu to eng. harness labled and ready to hook up and connect all wiring to engine hopefully!
Old Mar 16, 2011 | 08:38 PM
pprowler6's Avatar
good luck hope i helped haha.
Old Mar 29, 2011 | 07:18 PM
yes ill is good with no mil light! car started but need radiator and to button everything up. word of advice if you dont like head aches make sure and get a shell with all wiring!
Old May 4, 2011 | 10:44 AM
got my walbro 255 fuel pump $100
went out and played with my friend with a ws6 trans am but had zero traction! but was fun and should be promising hope too beat him with with a small shot of nitrous has anyone esle raced a ws6 ?
