TURBO ITEMS AND ECU
NEW CX RACING T3/T4 T04E Turbocharger, .50 A/R Compressor, .63 A/R Turbine, 5-bolt Exhaust, 3"inlet 2"outlet, 1/8 NPT Oil Inlet, 5-20 PSI working pressure, computer balanced individually. $150
NEW SARD FUEL PRESSURE REGULATOR $100
P72 OBD-1 ECU chipped (hondata) $150
NEW MSD 550cc High Imped FUEL INJECTORS $250
EXHAUST MANIFOLD 1 piece (Gasket included) This turbo manifold header is made with high quality stainless steel, Mandrel bent tubing, CNC Machined Flanges.
Bottom mount design, 35MM or 38MM external wastegate flange $80
NEW PLX WIDEBAND The PLX Air Fuel Ratio Sensor Module accurately measures the precise wideband air fuel ratio (AFR) of any internal combustion engine. Up to 32 Sensor Modules can be daisy chained together in the PLX iMFD system. This Sensor Module can also be used as a stand alone unit capable of interfacing with 3rd party hardware.Works with gasoline, bio diesel, ethanol, methanol, E85, LPG, and CNG. $250
INNERCOOLER 27X9X3 $80
2 DRIVER SIDE AIRBAGS FOR 94-01 INTEGRA BLACK & TAN AVAILABLE WITH GOOD RIBBON, & srs COMPUTER PASSENGER AIRBAG ALSO AVAILABLE make an offer
Also have piping and blow off valve $75 with cupplings
most of these items are new still in the box or never installed. All are in perfect working condition. New items were priced WELL UNDER retail. Call or text only if you are ready to buy 954-213-2421.
tachyon
Jan 27, 2017 10:23 AM
My_EFsedan
Northern California (Sales)
30
Feb 27, 2011 12:41 PM
