Jdm B16 trany and complete out to manual for sale
I have a Jdm B16 trany and complete out to manual for sale. The trany has a bad outer casing but i have one to replace it all you need to do is change the outer casing because it’s leaking oil. I had the paper work for this trany but gave it to the person who bought the motor that came with this trany. I could put you in contact with this person so that they give you a copy of the paper work.
The complete auto to manual includes:
Pedals
Clutch master cylinder and slave cylinder all oil lines
ACT lightweight flywheel
Exedy Stage 1 clutch with like 5K on it
Shift linkages
The screws to bolt the flywheel to motor and the once to bolt the clutch to flywheel
If you have an auto integra all you need is the auto to manual mount, if you have a civic all you need is a B motor plus the mounts you need depending on body. I’m looking to get 700 for this conversion. As far as trades maybe a set of nice wheels and money I’m located in central jersey and must be picked up!!!!
Pedals
Shift linkages
-jacob-
Transmission & Drivetrain
Oct 31, 2008 03:57 PM
danwants2btheman
Sep 13, 2006 12:33 PM
Campee
Dec 12, 2003 10:23 AM
