Mint si seats
Old Nov 24, 2010 | 03:14 PM
gnxpro24's Avatar
Default Mint si seats
I'll prolly get bitched at for posting this but oh well.Just got some mint condition 90-91 si seats and cant get them in my sedan. any thoughts besides pan swap? I heard the sedan pans are too wide which makes sense
Old Nov 24, 2010 | 09:27 PM
EL Vap133's Avatar
Default Re: Mint si seats
90-91 CRX Si seats or Civic Si seats?
Old Nov 24, 2010 | 09:58 PM
Eclectia's Avatar
I would suggest shipping the seats to me. Or maybe some sort of custom bracket.
Old Nov 25, 2010 | 01:08 AM
gnxpro24's Avatar
how much you paying haha
Old Nov 25, 2010 | 01:16 AM
Grey_Matter's Avatar
why was Honda so stupid to not make this Gen like legos....you'd think they'd have a brain and make them all interchangeable...aren't japanese people supposed to be smart? it would've cut production costs down alot
Old Nov 25, 2010 | 04:09 AM
AlfieRoach's Avatar
and yet we still choose turn purchase from the land of the rising sun
what year is the sedan?
Old Nov 25, 2010 | 08:03 AM
gnxpro24's Avatar
89 Sedan
Old Nov 25, 2010 | 08:21 AM
k20rex's Avatar
need to swap pans from your old seats if they dont line up
Old Nov 25, 2010 | 08:35 AM
gnxpro24's Avatar
looks like Im fabbing up some rails. Tooks of the rails from the sedan seats. Gonna have to mod them a little then get some 1/8-1/4 inch steel and make connecting brackets and make straps to connect the two rails together by welding. Then use tubing steel or such to make spacers since the si seats rail bolt spots arent level. Then use some longer bolts to go through the 1/8 or 1/4 inch steel brackets and into the seats. I'll post pics when I'm done. Im doing this right so theres no chance of danger for ne one in my car if I would ever wreck. Sick of seeing these people who just drill and stick a bolt through the floor un-reinforced or do it half assed putting other people and themselves in danger. Wouldnt it be great to wreck and have someone including yourself get thrown through the windshield cause u just ran a bolt through the floor or did it half assed? I think not.
Old Nov 25, 2010 | 10:03 AM
radex7's Avatar
A while ago I did this to get si seats in my older std hatch:
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/seat-pan-swap-revisited-civic-hatchback-1988-89-1990-91-upgrade-2687726/
I realize that sedan pan may be completely different, but it is just to give you an idea for something different.
Old Nov 25, 2010 | 11:10 AM
Projekt_Ef9's Avatar
Get 88-89 Si Seats or Custom fab them to fit. When the second gen integrs came out honda changed the floor and seat pans a little which is why 88-89 stuff doesnt fit the 90-91 stuff. Honda made most stuff between the integra and civic the same.
Old Nov 25, 2010 | 06:32 PM
macef9's Avatar
Old Nov 25, 2010 | 06:51 PM
efjones9's Avatar
pan swap is the only way unless u have a welder and are able to make custom brackets
Old Nov 25, 2010 | 06:54 PM
hondawhat?'s Avatar
if u nvr get em in ill take em off ur hands. pm me a price and a pic if u decide to sell
Old Nov 25, 2010 | 07:34 PM
gnxpro24's Avatar
read my earlier post, the paragraph I wrote, I have a welder
Old Nov 25, 2010 | 09:33 PM
James89DX's Avatar
This is exactly what I did. Only took a few hours.
It's not rocket science at all and of course, if you can do this you can literally put any seat in any car. That's why all the threads/questions/hysteria here about what seats fit into what car and what pans you have to swap blahblahblah is a little silly.
I put 90-91 CRX Si seats into my 89 DX hatchback by breaking out the welder and modifying my stock DX rails. I shifted the rails over by using bar stock to make "brackets". This bar stock was the perfect thickness for a couple of the corners, but since all the mounts aren't the same "height", the outer rear corners I used 1/4" steel plate to get the proper thickness/height and I think I had to double up on one of the front corners. Of course, you can then always use some washers to shim a little bit
Old Nov 26, 2010 | 10:30 AM
efjones9's Avatar
nice! the welds need to be a lil better than that for safety reasons.. but that is a good design.
Old Nov 26, 2010 | 01:05 PM
gnxpro24's Avatar
Im going to use steel strapping to go from one rail to another its thinner but much stronger youll see what I mean when Im done
Old Nov 26, 2010 | 01:18 PM
Creator's Avatar
I used 91 Hatch Si seats in my 89 DX hatch. Swapped seat pans, and because of the tilt adjuster being on the wrong side I put the Si passenger seat on my driver's pan. It was easy and the passenger side seat is always in better condition anyways.
Old Nov 26, 2010 | 01:29 PM
James89DX's Avatar
Just curious, in your expert opinion, what do you think is 'wrong' with my welds to say they need to be better "for safety reasons"?
Old Nov 26, 2010 | 02:20 PM
gnxpro24's Avatar
in my opinion the could be deeper and also welded on all sides, Im doing straps from one rail to the other to eliminate any weakness and to be supportive
Old Nov 26, 2010 | 02:54 PM
James89DX's Avatar
It is welded on all sides. The picture above wasn't finished, I just posted it to show that there is adequate penetration. Have you guys seen the stock welds on the rail brackets anyway? They're pretty paltry.
Anyway, I have no clue what you mean by using straps. You mean literally metal strap? I can't imagine you mean literally metal strap:
*edit* replaced the pic - didn't realize the original was so large
Old Nov 26, 2010 | 03:22 PM
gnxpro24's Avatar
hahahaha hell no Im using 1/8 or 1/4 inch steel made into "straps" or box steel that thick or even in L shapes for strength.
Old Nov 26, 2010 | 03:25 PM
gnxpro24's Avatar
edit. basically doing what you did except takinmg the piece the whole way over to the other rail with "plate steel", for strength, so the seats dont sit high
Old Nov 26, 2010 | 05:34 PM
James89DX's Avatar
Hmm, the sedan mounting points must be different from the hatch. There's no way I could have just used 1/4" plate on all four corners because the seat wouldn't hardly be level. My box steel was 3/4" thick. To make the seat as level as I could, up front, on one corner I had to use the 3/4" box steel PLUS 1/2" box steel on top of it to make it ~ 1 1/4" total. On the other side, it was just the 3/4" box steel. Then on one back corner I had to use 1/2" plate.
Also, on the hatch the seat has to be "offset" above the rails. Like this crude mock-up I did in paint:
Otherwise the seats are basically touching in the middle with about 10" in between the seats and the doors. When I first did it I realized the seats were WAY too close together and there was WAY too much space in between the doors and the seats so I re-did it and spaced them out.
IMO, if you want to do that idea, I would use 1/4" plate at the very least. But if the sedan is anything like the hatch, you'll have to make up different thicknesses on different corners to make the seats level like I did.
Anyway, in for pics when you start this! I really like how mine came out. Even with all my "spacing", they sit MUCH lower than my stock DX seats and is much more fun/comfortable to drive.
