Suspension & Brakes Theory, alignment, spring rates....
ASR on EKs
Old Nov 24, 2010 | 11:12 AM
jonesvirs's Avatar
Default ASR on EKs
is mandatory to have a swaybar to install the ASR subframe in a ek sedan chasis or i can use it without swaybar for a while ?
Old Nov 24, 2010 | 11:24 AM
90_EX_Civic's Avatar
Default Re: ASR on EKs
from what i've heard, any rear sway bar smaller then 19mm is okay. bigger then that, worry.
Old Nov 24, 2010 | 02:29 PM
98civdx's Avatar
Master Detailer
No, it is not. However is is recomended with anything bigger then a 19mm.
I currently have a sway bar with no brace, however it's only a 13mm.
What size sway bar are you planning to go with?
Old Nov 24, 2010 | 06:21 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
OP is asking if he can use the ASR brace WITHOUT a swaybar. I don't see why not, it's just like a tie bar otherwise.
Old Nov 25, 2010 | 05:29 AM
jonesvirs's Avatar
Thx to all u guys !
Old Nov 25, 2010 | 07:41 AM
Libertariat's Avatar
Ek Forever y0!
You can do that just fine. Progress actually makes a 22mm swaybar that doesn't need a subframe brace. It mounts up differently. Pretty interesting. Progress actually claims that the subframe brace is a waste of money with their bar.
Old Nov 25, 2010 | 05:49 PM
jdmboostedek99's Avatar
Asr with no sway bar for 2 years with no problem here!!
Old Nov 26, 2010 | 02:35 AM
Ek Forever y0!
2 years?
Sway bars aren't that expensive.
Old Nov 26, 2010 | 11:53 AM
spAdam's Avatar
Loved
Community Favorite
Maybe he just doesn't need one for his setup. Then again, an asr brace is pretty excessive without a bar.
Old Nov 26, 2010 | 12:58 PM
98civdx's Avatar
Master Detailer
I don't see the point in having a asr without a sway bar.
Well other than bling
Old Nov 26, 2010 | 04:22 PM
m_shake's Avatar
X2
Old Nov 26, 2010 | 09:02 PM
alphalanos's Avatar
I got mine before I got the bar for money reasons. But it was only a month or two. ASR + 22mm bar was probably the best thing Ive done to the car.
Old Nov 26, 2010 | 09:49 PM
98civdx's Avatar
Master Detailer
Well, I think that is a complety different thing. Not haveing the money at that point and time VS. buying the bar just for the appeal is different.
Idk, I am glad I'm not the only one who feels it is excessive or a waste of money to not actually use it for a large sway bar. I do know several poeple who only bought it for bling and have no intensions on using it for a larger sway bar.
Old Nov 27, 2010 | 08:23 AM
jonesvirs's Avatar
Im buying also the ASR Swaybar
Old Dec 7, 2010 | 04:06 AM
JDMFreak's Avatar
I have to say ASR makes a fine product, but using the plate alone is diffinitly bling! One expensive lower tie bar oh to the OP, yes it is do-able
Old Dec 7, 2010 | 08:52 PM
lxdriver's Avatar
Originally Posted by m_shake
X2
X3
Old Dec 8, 2010 | 09:00 AM
black magic's Avatar
Whats the point of getting an ASR brace if you're not planning on getting a sway-bar? That's just a waste of money. flash ftl.
tweek_boii
19
Nov 13, 2009 06:31 AM
ilvi3tkidxx
Feb 27, 2009 01:24 AM
kulo
Suspension & Brakes
20
Jan 25, 2009 10:02 PM
JDMCRX
Suspension & Brakes
Jun 14, 2008 03:53 PM
onsetofpurity
Suspension & Brakes
Jan 9, 2008 09:49 AM
