CRX A/C Question
I have a 90 crx, the kid i bought it from took every thing that had to do with ac and heat out. I have a 92 da that is wrecked, it has every single ac part on it. Can i swap all the ac components over to my EF lines and all? Will the fan box and heater core from the Da fit, im talking about all the under dash components?
I also installed the B18 and a b17 trans in my EF. When i look on ebay for a EF b16 trans mount i can only find the mount with no metal bracket, that bolts to the transmission. Will the EF b16 mount bolt to the DA metal transmission bracket? Note i have driver and rear trans mounts hooked up(Da mounts), the motor seems to sit fine.
Instead of using stock mounts should i buy this swap kit? http://cgi.ebay.com/ebaymotors/88-89...Q5fAccessories I really question the passenger trans mount in this picture, it looks to be a lot longer than : http://cgi.ebay.com/ebaymotors/INNOV...Q5fAccessories
Any one have some good advice from personal experiences here?
brian g
Jan 11, 2011 04:36 PM
CorrodeONE
May 4, 2008 09:18 AM
