HELP::--> Clifford Omnisensor & Glass Break Sensor & AG4
Do you have any idea on where I could get some more info on how to install/mount the Clifford Digital Omnisensor?
What about the wiring for the glass break sensor into an AG4?
Also, where do i hook up the following wire in my Integra?
AvantGuard 4 Control Unit: Wiring Description for the 14- Pin Connector
10 Gray Door trigger (+ or -)
What do you need to know about mounting the omni-sensor? mount it to something solid and plug it in. I mounted mine to the firewall under the hood.
I don't have the wiring schematic for the avantgaurd so someone else will have to help you.
From what you are describing it sounds like it is just an lock/or unlock wire. Find the wire in the car that locks /unlocks the doors and connect it here. I'll try to find the color code. I know some others here know what it is. I'm at work and will look later.
[Modified by nsxxtreme, 6:18 AM 9/23/2002]
i need to know if there is a specific way for mounting the omni sensor:
ie. horizontal, the up arrow pointing up or forward, etc.
for the door lock wires i needed to know where i could actually find the wires (physically), i know what color they are.
omni sensor arrow should point up.
Driver side kick panel is where you will find the wires you are looking for.
since the sensor is a shock sensor, should it be mounted VERY VERY securley to the frame with screws? or can I mount it to the under side of the dash with the double sided foam tape stuff?
I would say you want to mount it firmly to something. If you use double sided foam tape I think it will act like a cushion and dampen some of the shock. If you use screws the entire shock will get transfered to the sensor.
JDMCRX
Audio / Security / Video
Jun 7, 2009 05:44 PM
JBirch_97Prelude
May 27, 2007 01:03 PM
Powered By Garrett
Feb 17, 2007 08:31 AM
