Integra B18C, crank/start/ignition problem
When I start my car now I have to turn it and leave it in start position in the keyhole for it to finally crank and start. If I try to just start it, it will but then it dies right away.
I posted a video of me doing it.
Anybody have any idea what's going on, I don't think it's my battery because I just got a new one like a month ago.
http://www.youtube.com/watch?v=o0ChTVFMgxA
Almost sounds like you have to wait for the fuel pump to prime for a bit before starting it. To me it Sounds like a fuel delivery issue. With my kill switch on my car it will do exactly the same thing like your car is doing when you start it and dies right after.
If I understand you, the engine turns over, [cranks] when you turn ign. key to start and fires, [starts] but as soon as you let the ign. key go to the run position the engine stops running, if so...
Check your ign. switch...
http://www.visualimpressions.ca/switch/
http://techauto.awardspace.com/ignitionswitch.html 94
Audio28
Jul 3, 2003 05:33 PM
