liberty housing.....fix
Old Nov 23, 2010 | 02:50 PM
hello1320's Avatar
Default liberty housing.....fix
Just a heads up.....the throwout bearing slide was bent on my housing.....liberty took care of it no charge and I got it back in 2 weeks.
Apparently they completely remove the lower imput shaft bearing seat and the t/o bearing shaft and press a in a steel replacement......Iam sure the new housings will be like this....posting pics soon
Old Nov 23, 2010 | 02:56 PM
redboost10's Avatar
Default Re: liberty housing.....fix
That's the way they should all come. They are a nice piece for sure.
Did you have to do some grinding due to the flywheel teeth and/or pressure plate bolts rubbing?
Old Nov 23, 2010 | 03:02 PM
hello1320's Avatar
It was already done......but yes.....its not a big deal.....**** is mint now
Old Nov 23, 2010 | 03:31 PM
hello1320's Avatar
Old Nov 23, 2010 | 03:40 PM
zakura R's Avatar
Thanks for the head up now I will check my just to make sure
Old Nov 23, 2010 | 04:16 PM
xsi-t's Avatar
Originally Posted by hello1320
i thought you and rudolfo
were both using nrg housing or was only him?
Old Nov 23, 2010 | 04:22 PM
hello1320's Avatar
Lol....seriously. the NRG housings are being revised...I hope...cause those ****ers are thick. They just don't work.
Who's this ?
Old Nov 23, 2010 | 06:52 PM
rmercado's Avatar
we are using liberty's...no problems so far ;-)
Old Nov 23, 2010 | 07:02 PM
xsi-t's Avatar
u send back the nrg one?
Old Nov 23, 2010 | 07:39 PM
hello1320's Avatar
Incorrect...... YOU are using yours. LOL
Old Nov 24, 2010 | 04:00 AM
rmercado's Avatar
is true lol
Old Nov 24, 2010 | 04:32 AM
Topdawgg's Avatar
how much does a liberty typically go for, all said and done. Complete setup?
Old Nov 24, 2010 | 04:51 AM
SPOOLINmatt's Avatar
1750 for the bellhousing and 4150 for the gear set. Obviously you dont have to have the bell housing but it really helps a **** ton with flex. I hope to get one soon.
Old Nov 24, 2010 | 05:28 AM
Topdawgg's Avatar
how does that price compare to the PPG..? obviously the PPG is more expensive.
Old Nov 24, 2010 | 06:54 AM
locash's Avatar
Liberty fixed a few of our bellhousings like this a few months ago.. The broken gearset is another story..
Old Nov 24, 2010 | 07:36 AM
redboost10's Avatar
ppg is high 7k. in the two years i was using the liberty bellhousing and gear set, i never had a problem with customer service. broke 4th gear on the dyno and had gears in 3 days.
ldyer1994
Apr 23, 2015 08:19 AM
vtec_lude
Mar 16, 2007 02:52 PM
f22pwrdaccord
Feb 9, 2006 05:36 PM
komat
May 29, 2005 12:21 PM
pdiggitydogg
19
Mar 26, 2005 04:46 AM
