stage 3 cams
Old Nov 22, 2010 | 05:38 PM
nahonda04's Avatar
Surje.motorsports
Default stage 3 cams
looking into cams for all motor setup...was gonna go turbo but now im leaning towards all motor again...
anyway the two i was looking at were skunk2 tuner's and blue print racing...
anyone running either one or both or know where there are any graphs of either one with supporting mods...tried searching but brings up every question anyone has ever had about cams...
not looking at building the block right now, its a fresh swapped jdm b18c gsr....
Old Nov 23, 2010 | 04:43 AM
nahonda04's Avatar
Surje.motorsports
Default Re: stage 3 cams
need info bump
Old Nov 23, 2010 | 08:16 AM
Mattb16teg's Avatar
Community Builder
Community Influencer
So you wish to just drop in some stage 3 cams in your stock motor?
Old Nov 23, 2010 | 08:52 AM
00IntegrAllmotoR's Avatar
HT Black OPs
Which ever cam u go with, u will also need to upgrade ur valve train.
Old Nov 23, 2010 | 04:06 PM
wunfstgsr's Avatar
Loved
Community Favorite
sk2 pro 1 ftw!!!
216hp -high comp. gsr sk2 pro1's
Old Nov 23, 2010 | 08:28 PM
nahonda04's Avatar
Surje.motorsports
no...i said i am not building the bottom end atm...i know i have to put new valve train in as i am just asking questions about cams...
i understand the process of building a motor, i was just looking for opinions, reviews, insight, graphs etc...
two cams i am looking at are skunk2 tuner 3's and blueprint 3's...if you have experience with either one, let me know your thoughts on performance
Originally Posted by wunfstgsr
sk2 pro 1 ftw!!!
pro's are too aggressive without building the bottom end
Old Nov 24, 2010 | 06:06 AM
Mattb16teg's Avatar
Community Builder
Yes, you said not build the bottom end, you are out of your mind thinking of running any big cam on stock compression. Did you just pick the biggest cam you could find and say, "Hey, that sounds good!".
Why not build the block then buy cams, you don't need them now and need to learn some things first anyway, for you own benefit! Clearly you don't understand the process as you say you do so please go back to the drawing board on this one.
If you think pro 1's are too aggressive then what do you think stage 3's are!?!
Old Nov 24, 2010 | 06:32 AM
DVDr's Avatar
For a stock setup, I find the skunk2 tuner 2's match well ( upgrade exhaust,header and intake , and works great with a upgrade intake manifold like skunk2 or blox ).
anything bigger and you are shifting power band way to high or wont take advantage of it.
If you check the skunk2 site, they have dyno graphs etc.
( also it seems the skunk2 tuner stage 3s are great for the lsvtecs and bigger displacement ) )
Best of luck
Old Nov 24, 2010 | 07:02 AM
2LEM1's Avatar
I like to party
Community Builder
two cams i am looking at are skunk2 tuner 3's and blueprint 3's...pro's are too aggressive without building the bottom end
Lol, you obviously need to do some more research.
Dropping stage 3 cams in a stock bottom end sounds like a horrible idea. Pro 1 cams would be perfect, and definitely make more power than the stage 3s.
Old Nov 24, 2010 | 11:15 AM
Mattb16teg's Avatar
Community Builder
Best of luck
Tuner 2's are still relitively large for a stock motor and make 0 sense to install. Type stage 1s or type r cams. Which again aren't worth the 500 - 1000 for what they yield. And also need to be properly tuned to fully utilize the change.
LoL, and the comment about lsvtecs........... really?
Stage 3s would be equally useless in a stock lsvtec setup as well....... Also displacement has nothing to do with this equation because it's all relative to the compression in the motor.
Old Nov 25, 2010 | 05:58 PM
nahonda04's Avatar
Surje.motorsports
please forgive me i am coming from k-series, this is my first b-series hence why i asked questions...k-series we are just able to put valve train and stage 3 cams in with no problem...
Old Nov 25, 2010 | 06:07 PM
Mattb16teg's Avatar
Community Builder
Not really, same principles apply there as well.
Sure you can put them in no problem, are they going to make more power. probably not on a stock motor. They will over-cam the motor and not have enough air/compression to fully utilize them.
Old Nov 25, 2010 | 06:57 PM
nahonda04's Avatar
Surje.motorsports
actually that is all you need to do per i had them in my stock motor and made power considering compression on k20a2 is 11:0:1 and a stock 86mm bore...there is more than enough to flow power for stage 3 cams
you do realize i mod the K section of the forum....
Old Nov 25, 2010 | 07:33 PM
Mattb16teg's Avatar
Community Builder
Compression is high, but most stage 3 cams are overkill for a stock motor.......... There are other things that factor into the equation besides compression, as mentioned in my previous post.
Good luck with it though!
Old Nov 25, 2010 | 07:47 PM
nahonda04's Avatar
Surje.motorsports
not in k-series bud...but that is the reason i asked for b-series
Old Nov 25, 2010 | 08:21 PM
racebum's Avatar
1. you would get more help in the all motor forum
2. the skunk pro, endyn bumpstix and rocket cams all have been used in high hp all motor builds with great results.
3. the more displacement you have the better. a dart block and 2.2L stroker kit would be ideal
4. how did you become a mod and not know this?
Old Nov 25, 2010 | 09:57 PM
nahonda04's Avatar
Surje.motorsports
i asked in the all-motor section as well
ummm, i do know all this for k-series but not b...
and screw stroker kits, waste of money, rather build my own and just get machine work done...
i was in the process of doing an all motor k24/k20 frank...I-beam rods...12:5:1 compression, PR stage 4 cams, blueprint valve train with flat valves...stock 87mm bore..ported rbc, etc...
check my sig, you can find all the parts needed for a k24 bottom end minus rods, pistons and bearings...
had to sell/trade my rsx cuz i lost my job, again the reason why i asked questions for b-series per my first b-series build
Old Nov 26, 2010 | 12:14 AM
racebum's Avatar
basically the same idea for the B, if you have the bottom end down it's just which of those 3 cams you like the most
Old Nov 30, 2010 | 09:00 AM
2LEM1's Avatar
I like to party
Community Builder
nahonda04
Nov 25, 2010 11:34 AM
cleanep3
Jun 15, 2010 06:12 AM
matto2413
Sep 2, 2007 04:16 AM
t3to4e
Jan 4, 2004 06:20 PM
