T/B install on k series xcessive intake
Old Nov 22, 2010 | 05:23 PM
Slowcivik's Avatar
Default T/B install on k series xcessive intake-PROBLEM SOLVED!
i cannot find a thread anywhere on how to install a 90mm, or any other mustang tb or alike tb, on this intake. any info would help great. The sensors or relocation of sensors from the kseries tb is what i need help with. thanks ht
Old Nov 24, 2010 | 06:03 AM
rick_rabies's Avatar
I'm not Rick!
Default Re: T/B install on k series xcessive intake
try k20a.org.....
many weld a flange on or make an adapter. plenty threads there
Old Nov 25, 2010 | 12:41 PM
Slowcivik's Avatar
spent hours on shitty *** k20a with no luck. thanks though. im pretty sure u dont have to weld anything to the manifold either. im almost positive itll b a direct bolt on.
Old Nov 25, 2010 | 08:05 PM
Slowcivik's Avatar
problem solved. my main issues were the iacv and the purge control solenoid. apparently, as from the Karcepts web site, you can delete the iacv and disable it from your aftermarket ecu. the pcs on the other hand, ive seen people delete these entirely. im not sure whether or not it is disabled at the ecu though. 90mm mustang tb it is. thanks ht!
gian_ed7b16a1
Feb 17, 2016 10:38 PM
ewilliams1990
Mar 17, 2013 02:33 PM
b_serious
Dec 9, 2005 10:02 AM
InTeGrA GsR 321
May 5, 2005 10:55 PM
boosted k20
Jan 10, 2005 01:38 PM
