WTS: Misc DOHC parts
I have some different parts for sale for Honda/Acura DOHC motors. Some are brand new, some are used in great working condition.
AEM fuel rail in silver. BNIB $100.00
Autometer 2 5/8" mechanical oil pressure gauge 0-100 psi, black face Sport-Comp (comes with 6 foot -4AN stainless line) $30.00
Autometer 2 5/8" mechanical fuel pressure gauge 0-100 psi, black face Sport-Comp (comes with 6 foot -4AN stainless line) $30.00
Autometer 2 1/16" electrical AFR (not wideband) gauge, black face Sport-Comp (comes with 10 foot electrical connection, and sensor) $50.00
HONDATA S200 with all the options unlocked and a P28 ECU (chipped by HONDATA) $300.00
OBD1 GSR intake manifold with throttle body, fuel rail, and sensors on manifold. $75.00
OBD1 GSR air conditioner condenser radiator (sits in front if the stock radiator in the radiator support) $50.00
OBD1 GSR radiator with fans (excellent condition both fans work correctly) $100.00
DOHC VTEC gold valve cover with the cam gear ends cut off (done correctly with a bandsaw) $50.00
AEM 10 channel peak and hold injector driver (brand new, no box though). Comes with a custom harness to fit OBD1, so you do not need to cut anything on your harness. $250.00
OBD1 GSR long block (226,xxx miles) running excellent when pulled out of car. Vehicle was never taken above 4500 RPM. Head to oil pan $1000.00
I will get pictures if you guys need them.
Jason
Jason
BUMP:
Added to the list is as follows:
(1) pair of Full-Race B series cam gears $100/pair
(1) set of RC Injectors 1000cc/min low impedance $200/set
(1) set of RC Injectors 1600cc/min low impedance $200/set
The injectors have approximately 20 miles on them. Used them as a break in on a motor before switching out to a different injector.
Jason
Jason
VTECPWR
Feb 6, 2004 02:07 PM
