91 accord front end
Old Nov 22, 2010 | 11:02 AM
tyrone27's Avatar
Default 91 accord front end
hi i brought a 91 accord sedan and is has a messed up left front fender, left front corner lens, and left rear corner lens and I need to know if anyone has a how to on replacing them? i'm planing on doing it in 2 weeks because I have to replace the washer bottle too because its cracked and also resat the front bumper cover.
Old Nov 22, 2010 | 12:20 PM
sgraham01's Avatar
Default Re: 91 accord front end
remove the lower rocker molding (should be able to remove the front screw and tap it forward and pull out, twist the slips and they should come out of the body, then put the clips back in the molding before pushing it on). fender will unbolt and is pretty obvious once you start. you'll probably need the front bumper off to get the front bolts out near the lights. you can often just loosen the bumper and pull back enough of it to access the bolts without removing the whole cover.
VtecBio009
Dec 29, 2019 12:26 PM
510cd5
Aug 7, 2006 10:43 AM
Eagle16nam
Mar 10, 2006 03:58 PM
bearhug
Mar 10, 2006 03:09 PM
scottblade
Jan 3, 2006 03:16 PM
