Crank pulley question....
Old Sep 22, 2002 | 07:26 AM
Integra_Boi's Avatar
New User
Default Crank pulley question....
i have a friend with a b20, recently his bolt came loose and the pulley was just wiggling around(who knows how)... but it stripped the bolt and stripped the splines inside the crank pulley and broke the Key... i purchased the key/pulley already for him and still in search for the bolt because its on backorder from honda but my question is... where the actual pulley goes on... its smooth.. is it suppose to have something that splines onto the pulley? or was it smoothed out too...
Old Sep 24, 2002 | 12:45 PM
Stewie's Avatar
Default Re: Crank pulley question.... (Integra_Boi)
I'd say your screwed! The sprocket is supposed to have teeth and a slot for the key. What you should be asking is, How do I replace the crank pulley sprocket? I would suggest you post this in the tech forum.
Good luck!
[Modified by Mac8008, 9:46 PM 9/24/2002]
Spawne32
Aug 18, 2010 08:09 PM
bostoncal
Oct 24, 2005 07:37 AM
SuicideSlide
Oct 9, 2004 08:27 AM
david90
Aug 20, 2003 03:24 AM
david90
Aug 15, 2003 01:15 PM
