F22 valve cover bolt
Old Nov 22, 2010 | 05:09 AM
F22 Accord's Avatar
Icon2 F22 valve cover bolt
Does anybody know how to replace a f22 valve cover bolt?
I have tightened the screw to hard and peace of the bold broke off and now I need help how to change the screw and where I can buy it?
Thanks
Old Nov 22, 2010 | 08:32 AM
hondamark35's Avatar
Default Re: F22 valve cover bolt
you say "bolt" and not "stud/nut" so i'm assuming this is the VTEC model..?
left or right?
similar sites are listed in the Accord FAQs page-> HondaPartsUnlimited is a good place to buy from.
Old Nov 22, 2010 | 10:00 AM
F22 Accord's Avatar
left model
Old Nov 22, 2010 | 04:53 PM
nus_dogg's Avatar
Ouch. I hate when that happen. It'll be tougher to do unless you've been extracting bolts all your life. Good Luck though. I've learn my lesson by using a 1/4" drive with a 10mm bolt. I hand tight them til its tight then uses the 1/4" rachet by holding the head of the ratch will tightening it down, doing it this way will let you know that its tight already if you're following what I'm saying.
Old Nov 23, 2010 | 07:37 AM
F22 Accord's Avatar
do you khow how i can replace the bolt??
Old Nov 23, 2010 | 12:34 PM
holmesnmanny's Avatar
You just take off the valve cover and you'll see the bolt that's broke. Very easy to replace. Retorque to 10 ft/lbs.
Old Nov 24, 2010 | 04:20 AM
F22 Accord's Avatar
but is it just like a screw??
how do i remove the broken bolt?
Old Nov 24, 2010 | 08:02 AM
CDelgado220's Avatar
If it's # 14 stud in left model just remove valve cover and replace it.. simple.. Its not an actual bolt so its not inside the valve cover.
Old Nov 28, 2010 | 05:27 AM
caw's Avatar
caw
Are there any updates to this issue? I had the same thing happen and it looks like the only way to back out the broken bolt is with an easy out or removing the head and replacing the entire stud.
Old Nov 28, 2010 | 10:04 PM
It's a bolt that goes I believe from the rocker arm on up through the nut holes in the valve cover that you put a nut on to hold the valve cover to the head. When you take off the valve cover you will be using a 10 inch box wrench to take em off. The two closer to the front of the car are easy as pie. The two towards the back of the valve cover(or car) are a little more tight to reach but are capable. If you broke one of the front two it's gonna be a breeze. If it's one of the back two, it'll be a lil tighter to get the wrench on it.
Old Nov 28, 2010 | 10:10 PM
the white sam's Avatar
get the craftsmen bolt out set, and a drill, and your set, happend to me more that a few time's, that will take care of it.
Old Nov 29, 2010 | 12:32 AM
There is no need to chisel anything out on this particular bolt. It has a head at the bottom of the shaft of the bolt that you can put a box wrench on to unloosen it.
Old Nov 29, 2010 | 12:35 AM
http://www.hondaautomotiveparts.com/...=CYLINDER+HEAD
The front two are #16 the back two are #17
SlowB16si
Jan 28, 2006 02:13 PM
00ekcoupe
37
Sep 5, 2005 06:15 PM
renzema
Aug 29, 2005 09:42 AM
happy_guy
Aug 9, 2005 06:36 PM
LoudAccord
Jan 9, 2003 10:43 AM
