NEED WIRING HELP!!! Obd0-obd1 ef
Old Nov 21, 2010 | 04:25 PM
Justinleexxx's Avatar
Default NEED WIRING HELP!!! Obd0-obd1 ef
I swapped a d16z6 into a 88 civic that is dual point. I have been following a do it your self page that explains all the wiring, however right at the end it is really unclear about wiring the z6 harness into the main plugs. here is a link to the write up. http://www.angelfire.com/d20/hcivic8...nginecomp.html
This is the most popular artical about this on google, So I figured people must have used this write up before, I just don't know what I'm not getting.
We have looked all over the internet, and at wiring diagrams and is not clear what steps are next!
Old Nov 21, 2010 | 06:21 PM
xtremescouts's Avatar
Default Re: NEED WIRING HELP!!! Obd0-obd1 ef
you should only be using the z6 harness for parts. all you need is the four injector plugs, the dizzy plugs,the vtec solenoid and pressure switch plugs,o2 sensor plug, and a obd-0 to obd-1 conversion harness and a p28 ecu to do the swap. then use your original dual point harness and repin the neccesary wires at the ecu, run the wires for the new injectors, add the dizzy plugs, swap tps sensor outside wires, install conversion harness, install o2 plugs, extend a few plugs like the iacv plug, tps and maybe extend your fan switch wires and thats about it. there are numerous in depth writeups for a multiport conversion and none of them say to use the z6 harness that i know of. it is way easier to use the dual point and convert it over.
Old Nov 21, 2010 | 07:51 PM
JeffBro's Avatar
That is the noob approach where everyone always goes wrong on this swap. They think you will be splicing the main plugs. You never splice the big plugs. Just use the stock harness and then add the stuff you need to make it work from the z6 harness. Or you can use mostly any multi point harness to use parts from.
Old Nov 21, 2010 | 07:56 PM
HAMOTORSPORTS's Avatar
I still don't understand why people don't use a conversion harness for this kind of thing:
ECU Jumper Harness - OBD0 DPFI to OBD1
Old Nov 22, 2010 | 07:41 AM
low&slowef's Avatar
use a conversion harness way easyier save some time..
Old Nov 22, 2010 | 09:01 AM
jlicrx's Avatar
o.k. for the OBD0 to OBD1 ECU conversion, however, you still must convert the DPFI engine harness to MPFI in order to run the MPFI engine
Old Nov 22, 2010 | 09:23 AM
efjones9's Avatar
Send ur dx harness to me and ill do convert it 4 u with detailed instructions if ya want. Pm me 4 details
Old Nov 22, 2010 | 09:32 AM
EJ1_Sleeper's Avatar
to be honest I wouldn't trust my parts with someone who cant even type properly.
like everyone else said, you have to convert the plugs on the DX harness. Its easy and straight forward. look up DPFI to MPFI.
Old Nov 22, 2010 | 09:57 AM
jlicrx's Avatar
http://rywire.com/store/8891-crxcivi...56716c0bd7f8ee
Old Nov 22, 2010 | 09:58 AM
with the obd0 dpfi to obd1 harness you don't have to convert to mpfi first. It is all combined in the harness:
http://www.hamotorsports.com/obd0-dpfi-to-obd1.html
Old Nov 22, 2010 | 10:20 AM
Canadian_EF's Avatar
If you had read and opened the link, you'd see that MPFI conversion is also included in that harness.
EDIT: HAMOTORSPORTS beat me to it.
Old Nov 22, 2010 | 02:29 PM
efjones9's Avatar
hahaha. so on a site thats no where close to being formal u want me to type like d1 scholar? suck nutz hahaha
im jus tryn to help someone out that doesnt have much tech knowledge for less than rywires high ridiculous high prices and pay my way thru skool engineering school. haha yea so ej1 sleeper suk nutz
Old Jan 24, 2013 | 08:26 PM
Chris Sutton's Avatar
Folks,
We have a '91 crx SI (once had air conditioning) with D-16zc or perhaps z6-hard to tell on block? We took car to Best Buy to purchase and install new radio; they didn't do as Honda says and run a new ground wire, which then burned harness...
We have tried 3 other harnesses, none of which will fire motor. We are told an
OBD-1 conversion from OBD-0 wiring conversion will cure our problem? We will be happy to buy this kit, upon recommendations-advice of what we need-should do?
Thanks,
Chris Sutton
Old Jan 25, 2013 | 05:47 AM
90civic-ZC's Avatar
When you turn the key to on does the CEL stay on or clicks off after 2 seconds?
Old Jan 28, 2013 | 07:20 AM
boy, this is excellent reference...for myself, I am working on D-16 A6 wiring..
which is different.
Old Aug 18, 2014 | 04:49 PM
civicjdm19's Avatar
I need help im doing my first swap a d16z6 in a 1990 civic dx its a bare shell no engine no trans no ecu can i use a z6 engine harness and a obd0-obd1 jumper harness for the ecu?
Old Aug 18, 2014 | 09:37 PM
4drEF's Avatar
Keyboard Humorist
No. You don't use the z6 harness unless you are fantastic at wiring. It won't plug into the firewall connectors and you will have to repin everything correctly.
You get the engine harness for the chassis you have and modify as needed. If you have a DX then you need a DX harness, etc
Old Aug 19, 2014 | 12:50 AM
crx_si-r's Avatar
Wow. Since when is it a good idea to hack off a complete connector where your engine harness mates to the chassis harness.
I am dumbfounded by these idots.
Old Aug 19, 2014 | 01:05 AM
crx_si-r's Avatar
In response to the link posted at the beginning
Old Aug 19, 2014 | 02:55 AM
Freemananana's Avatar
Are the pins the same? I mean, my harness is soldered together all over the place. To be honest, the best idea would be to pull the pins and re crimp appropriate connectors on them all. And if you needed to extend a wire (TPS in a lot of cases), run completely new, solid, wires.
But we don't do that. So what is the harm in cutting another connector?
Old Aug 19, 2014 | 12:00 PM
crx_si-r's Avatar
Majority of the pins are the same. But the seals are different. Obd0 pkugs use bigger seals. So you will have to trim them down, if they are dried and hard like 90% of them are, to make them fit.
Old Aug 19, 2014 | 12:40 PM
You got me lost. I've always called the little metal connectors pins. I meant change those to whatever size is required to plug into the OBD1 plastic plugs.
lilchris813
Jan 27, 2012 10:43 AM
creepass
Apr 11, 2008 09:14 PM
WHORE: JDMCoveralls
Jul 8, 2006 07:07 PM
kingmonkey
Feb 16, 2006 08:27 AM
bobotron
Apr 25, 2005 08:42 AM
