code 16 on my mpfi swap
Old Sep 22, 2002 | 04:45 AM
ahc'monracing's Avatar
Default code 16 on my mpfi swap
code 16 is showing on my ecu and was wondering what to do. I know it deals with my injectors but I was wondering where should I start first? any ideas? oh yeah, how do check your injectors to see if they're working?
thanks a lot guys!!!!
Old Sep 22, 2002 | 05:15 AM
4gvtec's Avatar
Default Re: code 16 on my mpfi swap (ahc'monracing)
how does it run or does it? take off the neg battery terminal and put it back on in a min or so.start it and see if it comes back on.
Old Sep 22, 2002 | 12:52 PM
Default Re: code 16 on my mpfi swap (4gvtec)
it starts up but sounds really hollow and shitty....I just need info on how to check my injectors so I know if they all work or not. thanks.
Old Sep 22, 2002 | 01:11 PM
Perfectionist's Avatar
A code 16 is set when there is a break in the electrical circuit for the injectors. Anywhere from the main relay, resistors (if applicable), injector coils, and ECU, plus all the wiring in between.
H22Ej1
Jan 23, 2009 10:35 AM
SkIp_Civic_Ek6
Jan 17, 2007 07:37 PM
delux247
Jan 28, 2004 11:48 AM
Turbohatch
Sep 4, 2001 03:38 PM
