Passenger window won't go up! I'm freezing!
Old Nov 21, 2010 | 11:43 AM
jlowellintegra's Avatar
Default Passenger window won't go up! I'm freezing!
Today I put my window down and now it won't go up, could it be a fuse or anyone have a similar problem before?pls help Thanks
Old Nov 21, 2010 | 11:58 AM
el crapitan's Avatar
Default Re: Passenger window won't go up! I'm freezing!
you're trying it from the drivers side switch, correct?
you try from the pass. side yet?
Old Nov 21, 2010 | 12:02 PM
Tried both then pulled the fuse next to the battery put it back in and now I have no power windows on eitherside?!
Old Nov 21, 2010 | 12:17 PM
weird. k check the power window fuse under the dash
Old Nov 21, 2010 | 12:20 PM
Which one is that I bought the car without the plastic cover btw how do you know the fuse is done?
Old Nov 21, 2010 | 12:51 PM
well, since you probably don't have a test light, pull it out and see if the little metal ribbon inside has a break between the 2 terminals
Old Nov 21, 2010 | 12:56 PM
Ohkay can u tell me which fuse it is please
Old Nov 21, 2010 | 01:16 PM
****, i dunno, bud. couldn't find that out. may have to just start pulling the fuses and checking them until you find one that's burnt out. if you do
Old Nov 21, 2010 | 01:32 PM
Can any post a pic of the fuse cover under the dash so I cn see which is the power window fuse
Old Nov 21, 2010 | 01:38 PM
Old Nov 21, 2010 | 02:49 PM
Thanks bro
Old Nov 21, 2010 | 06:34 PM
you get it sorted out?
Old Nov 22, 2010 | 05:01 PM
No the fuses look okay but yet I lost power in both my doors when it was just my passenger window not going up t first???? Wth
Old Nov 22, 2010 | 05:23 PM
koss1229's Avatar
Do you have an aftermarket alarm installed?
Old Nov 22, 2010 | 06:12 PM
No but I think there might have been but the previous owner took it out because there's a little thing at the top of my windshield on the left with a skinny wire comin out? Eitherway just checked all fuses there good but no power in either one of my doors maybe my wire in the door going into the fender got cut??
Old Nov 22, 2010 | 09:31 PM
koss1229's Avatar
Yeah, I would get a tester and check the wires.
Anyways, if you're freezing, you can always use 12v off of your battery and roll the windows up :D
Old Nov 22, 2010 | 10:53 PM
check for power at the regulator
while pushing the switch, try giving the door a good smack where the regulator sits.
if it goes up, the brushes are just dirty and the regulator should be changed when you get time
Old Nov 25, 2010 | 04:23 PM
Figured it out....my door was unplugged lol!
Donkeeyyy
May 29, 2011 08:10 AM
EDWINV00SI
Jan 19, 2011 08:39 AM
Mylinh
Sep 8, 2010 06:25 PM
dcdcdc
May 9, 2008 08:23 PM
