Honda CR-V & Element 2WD & 4WD Element & CR-V
Help remove rear Knuckle
Old Nov 21, 2010 | 10:58 AM
meeps's Avatar
Default Help remove rear Knuckle
I have a 2002 CRV DX Japan built - trying to remove rear knuckle to change bearing. got everything cleared out - removed flange bolt from upper arm and the flange on lower arm is nice and loose - but the adjusting bolt won't budge...I have beat it, tried to turn it, yelled at it and it does not move. What am doing wrong? any ideas would be helpful - I am dead in the water with a car up on blocks.
Old Nov 21, 2010 | 02:42 PM
Hawkze_2.3's Avatar
Default Re: Help remove rear Knuckle
This help at all? Is it number 17?
Old Nov 21, 2010 | 03:45 PM
meeps's Avatar
Hawkze_2.3 Yes, it is number 17 and this schematic as well as the one I am using looks like it should just slide out. - But it won't budge - I have a jack under the trailing arm to support it. I have tried moving the jack up and down to relieve pressure to no avail - the bolt just won't move. I put a 14mm socket on it and it will not turn (I started to strip the head of the bolt-that's when I stopped and posted here.
Old Nov 21, 2010 | 06:19 PM
Hawkze_2.3's Avatar
Looks like there is a nut and a cam on the other end of the bolt...can you hold a wrench on either of those to loosen it?
Old Nov 21, 2010 | 11:33 PM
meeps's Avatar
The nut and the cam come off - the bolt itself won't move.
Old Nov 22, 2010 | 08:05 AM
Targa250R's Avatar
be professional
It's seized to the inner sleeve of the bushing. It will need to be drilled, cut, or burned out.
Old Nov 23, 2010 | 06:52 AM
Boosted Power's Avatar
+1.
I've done this many times before at work.
Old Apr 26, 2017 | 11:29 AM
Graybeard327's Avatar
Use a sawzall with a SHORT thin metal cutting blade. I just did this and it worked well for cutting the same seized bolt on my 2002 CR-V real trailing arm. Also be careful of cutting into the welded mounting bracket, that's why you want a short blade. If the blade is still too long, put it in a vise and snap off the tip to make it shorter. Hope this helps
albertdiaz3
Suspension & Brakes
11
Nov 26, 2014 04:42 PM
wes_foll_99si
Apr 16, 2010 03:36 PM
FuLlRaCe XLR8R
Suspension & Brakes
Feb 27, 2007 11:33 PM
dungsta
Jun 9, 2005 08:06 AM
CivicEK.PDX
Sep 12, 2002 06:42 PM
