NY fs: 92 boosted type r hatch/ 95 built b20vtec with goodies! =(
If you view this thread, PLEASE BUMP!
No Haters!
92 honda eg hatch, aztec green, 5 speed.
PART OUT! OR FULL CAR FOR SALE FOR 6K.
NO LOWBALLERS.
ENGINE:
* b16a2 w/type r head/intake manifold. Built w/je pistons/crower rods/sleeved/type r cams/valve springs and retainers/type r cam gears/ etc.Perfect compression, doesn’t burn any oil, no major leaks, etc. Meticulously maintained. Runs like new.
* garrett t3/t04e 60-1 a/r turbo. Zero shaft play. Runs/spools like new @ 10-12psi.
* DRAG log manifold w/custom external dump tube
* turbonetics clamps/hoses/couplers.
* precision fmic huuggge with custom stainless piping.
* hks ssq BOV. Very nice sound! Soft and subtle for daily driving; loud as hell when you get on it and want it to be loud.
* Custom 3inch downpipe w/ flexpipe/magnaflow exhaust.
* rc engineering 750cc injectors.
* aem fuel rail with aem fpr
* Walbro 255lph inline intank fuel pump.
* B&M FPR gauge.
* cometic head gasket
* PCV deleted.
* arp head studs/bolts
* Catalytic converter deleted w/ test pipe in its place.
* Stock O2 sensor deleted.
* 3inch stainless exhaust with magnaflow muffler. This + test pipe = VERY free-flowing, yet fast-spooling, exhaust.
* NGK 10mm spark plug wires.
* NGK cold copper spark plugs.
* MFactory magnetic oil drain plug.
* Custom polyurethane motor mount inserts w/hasport brushed aluminum mounts
* amsoil oil + new oil filter every 2,500 miles.
* GSR crank
* spectra intake cone
ENGINE MANAGEMENT/ELECTRONICS:
* chrome Chipped/tuned P28 ECU.
* hondata s200
* autometer pro comp amber boost gauge.
* auto meter procomp amber oil pressure gauge.
TRANSMISSION:
* type r trannyw/ quaife differential. Shifts absolutely butter smooth. No grinds whatsoever.
* skunk 2 short shifter w/ poly bushings.
* act stage 3 clutch & pressure plate.
* 7lb lightened flywheel.
* MFactory magnetic fluid drain plug.
* GM Synchromesh at every fluid change.
SUSPENSION/BRAKES:
* tein Sport adjustable 32 way coilovers.
* tein springs
* new sleeves
* brushed front upper strut bar.
* Skunk2 Pro Series front camber kit.
* BRAND NEW Brembo “drilled/slotted” rotors on front.
* BRAND NEW Hawk HPS pads on all 4.
INTERIOR:
* Amber kenwood CD player/radio. 6 1/2 pioneer speakers
* Full amber interior lighting conversion (every button/switch, gauges, etc.).
* OEM JDM Honda amber clock.
* Skunk2 weighted shift ****.
* Stock grey interior from B-pillar forwards.
* Gutted from B-pillar backwards (I have all the rear interior pieces, and they will be included with the car).
* jdm kmph dash.
EXTERIOR:
* Painted Aztec green Pearl.
* BKNW carbon fiber duckbill spoiler.
* vis carbon fiber hood w/ hood pins (deleted hood latch).
* spoon mirrors painted green
* password jdm EG amber sidemarkers.
* jdm taillights
* rota rims new shoes! All around
* dual halo projector headlights
* hid bulbs in high beams
* all badges shimmed
MAINTENANCE:
* Timing belt replaced ~100 miles ago.
* Water pump replaced ~100 miles ago.
* Clutch/pressure plate (act Stage 3) replaced & new 7lb flywheel ~4,000 miles ago.
* New thermostat, coolant flush, and coolant fill ~100 miles ago.
* New painted valve cover ~4,000 miles ago.
* New distributor o-ring ~4,000 miles ago.
* New fuel filter ~3,000 miles ago.
* New oil pan gasket ~4,000 miles ago.
* Brake system flushed/bled ~300 miles ago.
* New spark plugs ~4000 miles ago.
* New thermostat ~1,000 miles ago.
* 4-wheel alignment done ~100 miles ago.
Common questions answered:
* No parting out. No trades. Cash, money order, or cashier's check only. Will also accept PayPal + 3%.
* This car is not perfect. No car is. There are minor blemishes, little problems, etc. here and there. All of this will be disclosed 100% to the fullest to any potential buyers. its pretty perfect for the being 15+ years old.
* Will deliver if needed for an extra cost unless otherwise noted.This can all be worked out. However, I will not ship unless payed for in full and at buyers expense...
* If you ask to see the car and I tell you I’m going to meet you somewhere for viewing...don’t be offended. I don’t like strangers knowing where I live. Please show up too, I don’t drive places for fun esp far away.
* I do not have, nor have I ever had, dyno results/whp information. The car was built for reliability, It was built to be a quick/fun daily-driver/weekend-cruiser. My estimate is in the 300-350 range.
* i have never had, track/ET information. The car was ESPECIALLY never raced, nor have I cared enough to take it to a track and find out how fast it is. Again, it was built to be a quick/fun daily-driver/weekend-cruiser. My estimate is in the 11.3-12.0 range.
* The car is emissions-friendly.
What you’ll be getting as a buyer (in addition to anything listed above):
* the car.
* clean title in-hand. No leans or bs
* 1 set of keys.
* a few misc. things from around my garage that go with the car (extra gaskets, parts, etc.).
Finally:
If you have any questions, PLEASE ask!!! I want to answer everything you want to know about my baby! Please reply to this thread or PM me
Oh, and one last thing: NO free rides. Don’t come looking at the car without my asking price (cash in hand) and expect to get a test drive. I’m not gonna risk having it smashed. or broken due to inexperienced driver....
__________________________________________________ _______________
95 4 door integra base car 1300.00
cam gears obx purple with lock nuts/washers! 75.00
gsr head 225.00
milled 75.00/jet washed 40.00
crower cams stage 1 325.00
titanium valves, valve springs and retainers .. 350.00
valve adjustments 55.00
new oem hardware for head 89.00
wrinkle powder coated valve cover 75.00
jdm vtec solenoid 75.00 w/new gasket/screen
blox cam block 20.00
honed/bored block b20/85mm, jet washed, hot tanked. 325.00/120.00(block)
arp studs 125.00
Gator blue gsr timing belt - 84.00 shipped
Oem 22t vtec water pump - 50.00 shipped
Oem obdII b20 oil pump - 115.00 shipped
ARP rod bolts - 60.00 shipped (using stock LS oem rods)
ACL rod bearings - 59.00 shipped
Cometic 85mm head gasket - 80.00 (paid & left swerve)
12.9:1 YRP 85mm aluminum pistons and hastings rings - 279.00 shipped
Walbro 255lph fuel pump - 65.00 shipped
Precision 440cc injectors - 225.00 shipped
Password jdm dry carbon "whale *****" intake - 210.00
b18/b20 oem crank 200.00
new hoses all around 30.00
thermostat 15.00
oil/tranny fluids/rad fluid/zinc compound etc 95.00 x 2
final change after break in with synthetic 145.00
royal purple stay cool additive/distilled water mix for radiator 20.00
2 x Bride vios low max frp gradation seats w/sliders - 1520.00 shipped
f1 kms carbon racing mirrors with custom plates 155.00
sparco 3 pt harnesses silver/black 225.00
golden eagle vtec kit w/dowles 16.00
braided fuel line 25.00
greddy braided radiator hoses 125.00
10.2mm vision racing race wires 45.00
ngk plugs 7.00
skunk 2 intake manifold 225.00
aem fuel rail 125.00
aem fpr/gauge 25.00
pro sport digital oil pressure gauge 85.00
pro sport air/fuel gauge 275.00
dual guage flush dash pod 30.00
custom rota rims 600.00 shipped
pirelli tires 230.00
skunk 2 pro coils 775.00
buddy club camber kit (rear) 75.00
tri strut brace 50.00
aluminum spark plug wire cover 20.00
p28 chrome chipped ecu 145.00
vtec b16 dizzy 185.00
6pt BDR roll cage 185.00 plus install of 350.00
blox shifter **** 40.00
vision racing open end lugs 60.00
blox racing locking lugs 40.00
mishimots mini me radiator 90.00
fab slim fan 150.00
dc header 100.00
vibrant cat 75.00
powder coated custom exhaust(cat back) 125.00
tints 120.00/450.00 paint
2001 front end conversion 200.00
dual halo headlights 125.00
smoked clear fogs 55.00
jdm black honda badges 22.00 ( shaved all other badges)
viper alarm 275.00 installed
full hid 50.00
tilt license plat holder 20.00
short throw shifter 75.00
energy suspension bushings all over .....
new oem serpentine belts 45.00
new engine grounds 10.00 x2
lightened flywheel 7lb 125.00
stage 2 clutch/pressure plate exedy 225.00
JUST ADDED...
JDM gsr lsd tranny with progressive bushings/30k - 1000.00
carbon dinoc sheet 4ft x 11ft 400.00
radar detector 125.00
infiniti bass tube(amplified) 225.00
monster wiring kit 75.00
clarion touch screen/navi/etc. 450.00
memphis full internals/crossovers w/lifetime warranty 275.00
400watt amp for fronts 125.00(used)
chrome chip/tune by andy 300.00
1200 miles on build
9500.00 with bride seats/rims
8500.00 w/o rims
8000.00 w/o rims and seats.
MICS PARTS FOR SALE
- aluminum wire cover 25.00
- b series non vtec wires 30.00
- stagg struts w/oem springs 1200 miles on them 80.00
- 255lph fuel pump 85.00 nib
- jensen flip up screen/radio/mp3 etc player 225.00
- acura tach 8k rev 35k original miles 65.00
- cable gsr tranny with mounts 200.00
- ls tranny blown 2nd/3rd gear 655.00
Call/pm/text or post to me anytime and I will get back to you asap.
texting & calling me is best.
pics will be posted soon, or on request via email.
716 534 4020
nic
thanks guys.
**i dont want to sell these cars there fresh builds. but i ran into some major bills from recent surgery that caught me off gaurd. so i have no choice. these cars are pristine, run excellent, are extremely well taken care of, oil changed synthetic every 2000 miles or less and garaged. EVERYTHING ON THEM IS TOP OF THE LINE. please no lowballers.
No Haters!
NO LOWBALLERS.
ENGINE:
* B&M FPR gauge.
* PCV deleted.
* GSR crank
* hondata s200
TRANSMISSION:
SUSPENSION/BRAKES:
* tein springs
* new sleeves
INTERIOR:
* jdm kmph dash.
EXTERIOR:
* jdm taillights
MAINTENANCE:
* the car.
* 1 set of keys.
Finally:
gsr head 225.00
arp studs 125.00
thermostat 15.00
ngk plugs 7.00
aem fpr/gauge 25.00
fab slim fan 150.00
dc header 100.00
vibrant cat 75.00
full hid 50.00
JUST ADDED...
1200 miles on build
8500.00 w/o rims
MICS PARTS FOR SALE
716 534 4020
nic
thanks guys.
No Haters!
NO LOWBALLERS.
ENGINE:
* B&M FPR gauge.
* PCV deleted.
* GSR crank
* hondata s200
TRANSMISSION:
SUSPENSION/BRAKES:
* tein springs
* new sleeves
INTERIOR:
* jdm kmph dash.
EXTERIOR:
* jdm taillights
MAINTENANCE:
* the car.
* 1 set of keys.
Finally:
gsr head 225.00
arp studs 125.00
thermostat 15.00
ngk plugs 7.00
aem fpr/gauge 25.00
fab slim fan 150.00
dc header 100.00
vibrant cat 75.00
full hid 50.00
JUST ADDED...
1200 miles on build
8500.00 w/o rims
MICS PARTS FOR SALE
716 534 4020
nic
thanks guys.
No Haters!
NO LOWBALLERS.
ENGINE:
* B&M FPR gauge.
* PCV deleted.
* GSR crank
* hondata s200
TRANSMISSION:
SUSPENSION/BRAKES:
* tein springs
* new sleeves
INTERIOR:
* jdm kmph dash.
EXTERIOR:
* jdm taillights
MAINTENANCE:
* the car.
* 1 set of keys.
Finally:
gsr head 225.00
arp studs 125.00
thermostat 15.00
ngk plugs 7.00
aem fpr/gauge 25.00
fab slim fan 150.00
dc header 100.00
vibrant cat 75.00
full hid 50.00
JUST ADDED...
1200 miles on build
8500.00 w/o rims
MICS PARTS FOR SALE
716 534 4020
nic
thanks guys.
i forgot i have a new BDR racing 8pt roll cage also for 2-4 door tegs pre bent and cut ready for weld in. i want 125.00 for it.
ok i will go on photobucket and get some pics up asap! thanks guys. anyone interested!!! im in a bad situation financially right now. i have a crap load of money into these fresh builds!! asking next to nothing compared to what i just spent on everything brand new! i have receipts.
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
heres the pics as i promised guys sorry for the delay.
I ALSO AM FABRICATING CUSTOM BLINKERS FOR HONDAS/ACURAS.
THEY WILL BE THE CLEAR BLINKER HOUSING WITH A FULLY REDONE INTERNAL
LIGHTING SYSTEM. WILL BE LIKE THE AUDI R8 RUNNING LIGHTS AND A SEQUENTIAL BLINKER THAT BLINK OUTWARD 5-8 LED LIGHTS FOR THE BLINKER AND SAME FOR THE RUNNING LIGHTS ALL IN THE CLEAR HOUSING. YOU WILL BE ABLE TO CHOOSE YOUR CUTOM COLOR OR ACCEPT THE ONE THAT IS LEGAL WHICH IS AMBER SEQUENTIAL BLINKER/WHITE RUNNING LIGHT. I WILL HAVE A PROTOTYPE UP ON HERE WITH PICS/VIDEOS OF IT MOCKED UP ON MY ACURA BEFORE ITS SOLD. SO KEEP POSTED. LET ME KNOW IF INTERESTED. I WILL HAVE THEM IN LOCAL RACE SHOPS VERY SOON FOR NOW IN BUFFALO.
[/IMG][IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG]heres the pics as i promised guys sorry for the delay.
thanks! anyone! i have a ton of local offers. but no solid offers yet. a few pending but money talks. im looking to get rid of these soon. make some offers guys. again the prices associated with the parts are NOT the cost for the parts. it is what i paid for them so you have an idea of what i spent on the car in a whole. please dont write me emails asking me for parts and talking me down on prices. i am only parting the teg of bride seats/rims and belts if i get reasonable offers. everything is a month or less old. no lowballers please. and the honda i will only part out if i have a solid list of just about everything sold also. NO TRADES. i need cash to pay bills not "stock" cars to drive or a trade for your newer car for "both" my cars??? not interested.
i hope this clears things up in a whole.
i need cash im in a horrible financial bind.
i do not want to sell these but i am forced too.
and i know its a bad time to sell a built car but like i said i dont have a choice.
txts/calls are great.
716 534 4020.
thanks in advance!
716 534 4020.
thanks in advance!
both cars pending as of today! lots of parts for sale!!
-sparco harness's (150.00)
-kms carbon mirrors (150.00)
-carbon pswrd jdm whale ***** intake (180.00)
-rota kandy rims/new tires (800.00)
-blox shifter ****/boost gauge (40.00/50.00)
-pswrd jdm hooks (front and back) (100.00)
-rims/tires (450.00)
-prosport airfuel new/extra sensor (175.00)
-single pod 20.00 new
-glowshift digital boost gauge new (75.00obo)
-turbosmart boost gauge mechanical unit from japan(in bars) 35.00 minor dent in rim
-prosport oil pressure gauge digital 3 color (80.00)
-misc blinkers (10.00)
-mugen valve cover (125.00)
-non lsd cable tranny with all mounts/shift linkages/poly shifter mount/shifter. 200.00
-ls tranny needs rebuild (offer)
-rear defrost button 15.00
call / text me if interested in anything. will do packages if more then one item is bought.
716 534 4020
thanks guys!
716 534 4020
thanks guys!
