Breather/Recirculation box block off
checker/ oreile auto parts sells a plug. has a bolt and nut that turns then making the plug expand. its usually found in the HELP! department. autozone might have one too. good luck
or get the kit from GO autoworks that allows you to hook a catch can. you block NEEDS to breath or you could cause possitive crank case pressure and ruin your rings.
http://www.go-autoworks-store.com/gobseblfiset.html
