E-85 conversion questions
Old Nov 19, 2010 | 08:30 PM
flipmoderacing1's Avatar
Default E-85 conversion questions
I have a 94 Accord Coupe and I want to take it from gasoline to E-85. Other than changing my injectors and ignition system, what all do I need to do to make my Accord run on E-85?
Old Nov 20, 2010 | 05:59 AM
ilikehonda's Avatar
Default Re: E-85 conversion questions
something to tune the car with. e85 typically requires 30% more fuel.
why do you want to switch?
Old Nov 20, 2010 | 07:36 AM
hotaccord243's Avatar
fuel pump to push that extra volume of fuel required to meet a/f requirements.
Probably help to have a a/f wideband to keep an eye on the a/f ratio.
Old Nov 20, 2010 | 09:40 AM
ilikehonda's Avatar
if you do not know what you are talking about please dont post.
Old Nov 20, 2010 | 09:49 AM
Bwill9886's Avatar
If you are wondering whether you really need to change anything as far as the fuel lines and whatnot, you really don't. There are quite a few people on here running the stock stuff with no issues.
You may hear some people say they've had problems, but from what I've gathered most of them seem to be more from bad luck or other issues. Check out the Forced Induction forum for more info.
Of course they typically have bigger injectors and an upgraded fuel pump setup because most of them run E-85 for their turbo setups. What kind of setup is this going on?
Old Nov 20, 2010 | 06:08 PM
G22 turbo set up. Ive already got a 95 gph fuel pump, afc v-afc, Drag cell, and i'm look for sum 1000 injectors. So other than that I have no clue...
Old Nov 20, 2010 | 08:31 PM
Bwill9886's Avatar
As I said, you can go ahead and browse the Forced Induction forum for more info, but here is the best start:
https://honda-tech.com/forums/showth...highlight=E-85
Old Nov 21, 2010 | 12:15 AM
nus_dogg's Avatar
I heard it really corrodes your fuel components; thus, why some ppl start having problems with their car after converting to E85 is what I heard; don't quote that on me.
Old Nov 21, 2010 | 08:53 AM
Bwill9886's Avatar
That is, as the facts stand now, a myth. If anyone here has someone tell them that E85 corroded their fuel lines, injectors, etc., I would question them on what facts they have to prove that it was SPECIFICALLY the E85.
As I said before, there are quite a few people on H-tech running stock fuel systems with no issues. The only things you should REALLY think about upgrading are the injectors, fuel pump, and the fuel filter (stainless-type).
For anyone who may have more questions, or just is curious about E-85, read the link I posted above. There are some facts that may surprise you (for best results read/skim the WHOLE thing... I know, its hard, but there is good info throughout).
Also, you can take a look through this thread if you are wondering about testing fuel system parts for corrosion:
https://honda-tech.com/forums/showth...ht=e85+testing
Old Nov 21, 2010 | 02:07 PM
@ Bwill9886, Thanx for the info man.
Old Nov 22, 2010 | 06:10 PM
uberEFtuner's Avatar
Why are you wanting to covert to E85? I read that in drag racing its worth 5% to 8% on a naturally aspirated setup.
As for conversion all rubber need to be replaced. E85 will dissolve regular rubber.
Old Nov 22, 2010 | 06:30 PM
Bwill9886's Avatar
Well the OP is piecing together a turbo setup, as you can read above.
It has been noted in testing that E85 does alter the properties of certain rubbers/seals in a negative way.
Here are the results of one such test:
http://www.thefreelibrary.com/Fuel+a...s.-a0168089903
However, as I stated before, many people in the drag racing and forced induction world have been running it in their stock fuel system for a while with no ill effects.
So take what you will from that.
Refer to posts above for other items that have been proven to be necessary.
Hondaboy089
Engine Management and Tuning
Nov 30, 2015 04:19 AM
Lyle_57IAL
Apr 22, 2015 04:22 PM
civic-r11
Apr 5, 2009 02:57 PM
user 9782082308
Nov 13, 2005 06:50 PM
ScottEK
Audio / Security / Video
28
Aug 23, 2002 02:12 PM
