b17 tranny mounts?
im putting a b17 into my 93 ls. i had a b16 in it with the hasport mounts on it. the mounts dont match up with the gsr so i need new ones. my question is... do i need mounts from a 93 ls or does it have to be from a 93 gsr?
Go on innovative's website they have motor mounts and I did see that they have different sets if you have a DA GSR. Might give you some info..Hope that helped a bit. By the way, is that a stock B17? Just picked up a B17 block that needs rebuilding. I was wondering how it would feel compared to the B16 I had at one time in my old DA..LmK!
NO NO NO> The 92-93 GSR had different chassis, Same with the 90-91 Integra's. so the motor mounts are different for the 92-93 GSR's than the 92-93 LS, and RS. The mount you probably have is from a GSR. So use a 93 LS Tranny mount. Which you should already have in your car.
the only difference in the 90-93 integra mounts between the years is the drivers side mount
yes the 92-93 gsr shared the same chassis as the 90-91 meaning they use the same drivers side mount
90-91 drivers and 92-93 drivers are different
the rear mount and transmission mounts are the same for the 90-93
no i had hasport mounts in it cuz i had a b16 with hydro to cable conversion. i bought the car like that so i dont have the original mounts. but ima find one online this week and order it.
tru_pimp
Sep 8, 2005 05:04 AM
