98 accord lx...no power windows etc....not multiplex
Old Nov 19, 2010 | 06:41 PM
jaypain's Avatar
Default 98 accord lx...no power windows etc....not multiplex
so ive got a 4dr 98 accord lx. let me go through the list...first, the wipers will not turn off. they will only go slow or fast, no intermittent. no power door locks and no power windows from the drivers master OR the individual door/window units. the only window that works is the drivers. i have done the multiplex wake up, changed the wiper motor, wiper relay, and the wiper switch on the column....no change. could this all be linked to the other multiplex control units? close to just buying and replacing at least the drivers side unit, but if that doesn't solve this i'm going to lose it. ideas? and yes...ive checked each and every fuse, and manually powered each window motor. HELP!!!
Old Nov 21, 2010 | 07:37 AM
jaypain's Avatar
Default Re: 98 accord lx...no power windows etc....not multiplex
bump
Old Nov 21, 2010 | 10:42 AM
My02accord's Avatar
I'm newish to hondas so cant help much but curious what's the multiplex wake up?
and here's a bump
Old Nov 22, 2010 | 07:40 AM
stereo's Avatar
Download some wiring diagrams for your vehicle and list all the problems you have on a sheet of paper. Cross reference you problems with the diagrams and see if they have any common circuits. It would be a good idea to check your ignition switch circuit. The window circuits are linked to the ignition circuit when you turn the key from off to accessory and then to start. The wiper problem is odd but ignition switch problems have a cascading effect on other circuits related to the wipers and it could be causing this somehow. Take some advil before you start too because wiring is a serious headache!
Old Nov 22, 2010 | 08:27 AM
jaypain's Avatar
check this out....when i pull the relay under the hood for the wipers....still no intermittent, but i have off, low, and high.
95accord-R
Feb 3, 2014 11:56 PM
jaypain
Audio / Security / Video
Nov 23, 2010 06:52 PM
fcm
Nov 20, 2008 12:02 PM
codyJDM
Nov 3, 2008 04:33 PM
cjwelch
Dec 11, 2001 06:23 AM
