help! Wont go into Reverse gear..
Old Nov 18, 2010 | 09:07 PM
JDM-LuxurySport's Avatar
Default help! Wont go into Reverse gear..
Hi there guys, today i gunned my integra on highway because of this stupid tiburon and now my car requires hercules muscles to shift into reverse gear. Other gears are fine its only the reverse gear, what could have gone wrong? Its a GSR transmission.
Old Nov 18, 2010 | 09:44 PM
20-EM2-05's Avatar
Default Re: help! Wont go into Reverse gear..
Could be the fork?
Can't be any bearings or syncos that i'm sure of.
Try doing the 1st to reverse method?
Old Nov 19, 2010 | 04:58 AM
fv8s's Avatar
Originally Posted by 20-EM2-05
Could be the fork?
the reverse gear does not use a fork, it uses an independent lever and independent gear. I would open up the case and check to see if it came off its rod or is not on the lever correctly.
http://img329.imageshack.us/i/1003141op3.jpg/
The reverse gear is the one all the way at the top right (then go left one and down one)
Old Nov 19, 2010 | 08:46 AM
Damn i hoped i dont have to take it off Its god damn cold outside.
Old Nov 19, 2010 | 09:21 AM
fv8s's Avatar
take the reverse light switch out located at the bottom of your trans to get a peak inside. a 19mm wrench will take it out. I recommend draining all your fluid and putting in 2.5 quarts of Gm/pennzoil synchromesh also.
killerpenguin21
Transmission & Drivetrain
10
Jun 3, 2009 02:01 PM
Kevykev
Acura TSX
Jul 13, 2008 09:33 AM
wrx'n you
Dec 21, 2005 08:20 AM
bustedasscivic
Nov 16, 2003 09:59 AM
not so civic
Jun 18, 2003 09:07 PM
