Suspension & Brakes Theory, alignment, spring rates....
89 ef sedan suspension suggestingss??
Old Nov 18, 2010 | 08:54 PM
ekcid97's Avatar
Default 89 ef sedan suspension suggestingss??
hi guys well im on a buget and need new suspension...vuz mine came with some no name crap that is bounceyy as hell....
sooo u guys have any suggestingss??
thanks.
Old Nov 19, 2010 | 03:54 AM
ekcid97's Avatar
Default Re: 89 ef sedan suspension suggestingss??
bump!!!lookin for a smoomth ride that can handle corners weell
Old Nov 19, 2010 | 11:40 AM
BLU CIVIC's Avatar
Track Advocate
research, research, research, then ask knowledgeable questions based on your research
Old Nov 19, 2010 | 02:11 PM
ekcid97's Avatar
ok well i have been doing research.....and dont know weather to go with a tokico shocks and ground control springs combo cuz im on a buget and want to tightin up my handling and have a smooth ride at all speeds....no bounce..
Old Nov 19, 2010 | 09:45 PM
98civdx's Avatar
Master Detailer
What kind of tockio's? What"s the budget?
Old Nov 20, 2010 | 12:10 AM
EJ1_CRIS_909's Avatar
Tokicos wit ground controls are a good set up.. id say go wit that..
You wont be disappointed..
Old Nov 24, 2010 | 12:52 AM
ekcid97's Avatar
ok so the other day i look at my rear end and it looks like a have ground control coil overs on the no name springs or something...cuzz is the same no name blue springd like in the front but with gold and red coil overs hummmm...might start messin around cuz my tires are waring bad on the inside....would that help stop that
Old Nov 24, 2010 | 09:58 AM
98civdx's Avatar
Master Detailer
Getting an alignment would help.
Old Nov 26, 2010 | 08:29 AM
if your car is pretty slammed, not just an alignment will help... Youll also need a front camber kit so they can adjust your alignment better. AND DONT GO WITH CHEAP ONES!! Look around and get some good quality ones. I heard skunk2 are good. Then youll have even wear among your front tires.
Old Dec 7, 2010 | 10:23 AM
ekcid97's Avatar
thanks man yeahh i am gonna get skunk2 caber kit in the front had that kit on my ek.....ok soo i looked at my rear end again and i foud that on the right side the spring is soo short like when i lift the car the spring can move up N DOWN.....now i dont think thATs good...can someone help me out please.......
should i ajust it so the spring hitsss.....??????
and yea my car is pretty low hate it cuz its all bounce to.....
thanks guys.........................
Old Dec 7, 2010 | 10:26 AM
ekcid97's Avatar
i know man im gonna do that but i wanna get my suspension done first....
no needd to get an alignment if im jus gonna change it up again......
thanks...
Old Dec 7, 2010 | 11:48 AM
90_EX_Civic's Avatar
that's normal for a collar type coilover. if you were to do that with the left side it would probably do the same.
and why not raise it up first and see if it fixes your bounciness? sounds like you're on your bump stops and that is causing your horrible ride.
Old Dec 7, 2010 | 12:12 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
No.
https://honda-tech.com/forums/suspension-brakes-54/no-you-do-not-need-camber-kits-2614449/
Old Dec 7, 2010 | 12:33 PM
Originally Posted by PatrickGSR94
No. skunk2 upper control arms are crap.
https://honda-tech.com/forums/showthread.php?t=2614449
fixed
Old Dec 8, 2010 | 01:45 AM
ekcid97's Avatar
bumb stops???whats that sorry first build......
and so a skunk2 camburg ket is a no no
Old Dec 8, 2010 | 05:37 AM
bump stops are the rubber(polyurethane) bushing that sits on the shock shaft. there's a technical purpose for them but i don't remember it right now.
skunk2 are okay. you will have problems with them if you are to low. the upper control arm will hit your shock tower, and make a dent after a while.
Old Dec 8, 2010 | 09:08 AM
ekcid97's Avatar
oo ok fosho fosho yeah to day ima lift my car an mess around back there and rase it till its flush on both sides....and theres no rubber on my springs at all give more updates when im done thanks guys...
and wouls a aliment fix the wear on my back tires or wouls i needa but other parts to????
Old Dec 8, 2010 | 10:25 AM
.......umm
the rubber im talking about is on the shock shaft, the silver part in side the springs.
tire wear, it depends. you might actually have a bad bushing, like your trailing arms. wont know till you take a better look.
Old Dec 8, 2010 | 11:37 AM
ekcid97's Avatar
.......umm
ok i know that i need new bushings in the front most likey in the back to......
sooo my rear trailing arms might be bad.....
should i meess with my coil over and rais them so they dont move when i lift my car?>?????
cuz my tires wear bad on the inside how i got it sucks.....it came all stock but the suspension........
the only reason im not messin t=with the coilovers right away cuz if i life the back wouldent that jus make my front end lower????
Old Dec 8, 2010 | 12:07 PM
Community Builder
There is NO WAY to fix the tire wear yourself. ANY time you mess with ride height, alignment changes and a 4-wheel alignment is required to fix it and prevent future excessive tire wear.
*edit* well there are ways to do a DIY alignment but it can get pretty complicated and you won't have near the accuracy as you would on a 4-wheel laser alignment rack */edit*
If you raise the spring perches to where the springs are all captured at full suspension droop, you will likely have a 4x4 ride height, depending on spring length of course. You needn't worry about uncaptured springs at full droop, because that condition almost never happens when driving the car, unless you like to do Dukes of Hazzard jumps and stuff.
What you need to do is get the ride height where you like it, get it aligned, and then DON'T MESS WITH IT. It would also be best if you replaced parts that needed replacing.
If you can't replace all the parts now, then go ahead and set your ride height and get it aligned. But just remember that you'll need another alignment when you do replace the worn out parts.
Old Dec 8, 2010 | 12:12 PM
..... umm
question is now how low are you in the rear? are you slammed, all around? raise all 4 corners, and if you raise it up till there is no slack (the spring doesn't move around anymore) then your looking at an almost stock height.
the springs will be loose, and it will be okay. don't worry about it. if you really want that fixed. you're going to need to buy new extended top hats, and helper springs.
more likely for you you would need helper springs. they are just a spring that will help to keep the coil spring from moving around much.
edit* and what Pat said.
Old Dec 10, 2010 | 01:10 PM
ekcid97's Avatar
thanks alot guys....yeah im not gonna mess with it and ima jus start bye new parts...i wAnted to do it anyways so ima jus save up and get it all new but what sucks is im gonna have to bye all 4 new tires......
u guys have any suggestingss on what kinda tires to get that will last and good road tires.......for like mountian roads nott off road.....
Old Dec 10, 2010 | 01:15 PM
ekcid97's Avatar
..... umm
yea i kn ow i needa get extended top hats.....my car is like 9in from the bottom in the rear bumper.... an i only have coilovers in the rear end.....
Old Apr 14, 2011 | 04:42 PM
ekcid97's Avatar
so i got some brand new tokico hp series blue shocks for my car....
an i wanna get some d2 lowering springs 2.25in drop....
has anyone useed this setup befor an if so give some info please thanks again h-t.
an would i have bye extened top hats or have some made?????
Old Apr 14, 2011 | 04:51 PM
Community Builder
You need to sell or return those shocks and get something better. Those shocks will blow out quickly with that much of a drop. Tokico HP shops are crap for anything more than the slightest lowering.
