Fitment: 225/45/15 RS3 15x7.5 +42 fit on 97 Integra?
Old Nov 18, 2010 | 04:01 PM
Flier129's Avatar
Default Fitment: 225/45/15 RS3 15x7.5 +42 fit on 97 Integra?
As the title says, wondering if a set of 225/45/15 RS3's on 15x7.5 w/ +42 offset on a 97 integra with GC's. Not sure on the alignment numbers, under -2.5 degrees though.
Looking for a quick answer, suppose to run an autox with them on Saturday.
FWIW the same setup was mounted on a crx with similar suspension and rubber on the trailing arms. Will there be more room with the integra?
Forgive me for my ignorance, I'm not a honda guy lol.
Old Nov 20, 2010 | 04:11 AM
PSU's Avatar
PSU
formerly DxHatchback
Default Re: Fitment: 225/45/15 RS3 15x7.5 +42 fit on 97 Integra?
You should be more than fine seeing how a 205 is standard for an Integra.
Old Nov 21, 2010 | 08:12 AM
Flier129's Avatar
They fit fairly well. The tire was about 1/4 an inch away from the trailing arms. Didn't rub the front fender either.
Turned out to be a good fit over all.
Old Nov 23, 2010 | 03:58 PM
BanzaiBeast's Avatar
The Hankooks in that size are virtually the same as a 205 Falkens I ran on my '97 GSR with 15 X 7 1/2" Slipstreams. They would rub in the rear a little, I had about -1degree of camber and the car was sitting a little high, (lower control arms about level).
P.S. Tell Rich with the GP Bugeye, Greg says Hi!
Old Nov 23, 2010 | 04:45 PM
highroller54's Avatar
I'd love to see pics of that setup on the car!!!
Old Feb 16, 2011 | 12:43 PM
cletus11's Avatar
What brand and model of wheels are you running? The tirerack has the TR C1 in 15x7.5 with a 42 offset. I assume these will work as well.
Old Apr 26, 2011 | 11:16 AM
Muckman's Avatar
Moderator in Chief
Do 15x7.5 +42 stick out past your fender? Would also like to see pictures.
97 Civ Rip
Apr 27, 2011 04:00 PM
soloteg
12
Apr 26, 2011 06:09 PM
norbs_crxsi
Aug 11, 2008 04:18 PM
redGSRguy
Nov 9, 2006 11:28 AM
WNT KCH
Oct 13, 2001 09:47 AM
