speed sensitive suspension damping
Old Nov 18, 2010 | 10:54 AM
h2.4's Avatar
Default speed sensitive suspension damping
I was seeing if anybody knows of any strut manufacturers that have speed sensitive damping available.
Old Nov 18, 2010 | 10:59 AM
YZFR6's Avatar
Default Re: speed sensitive suspension damping
The only shock that I know that has low speed and high speed is the Penske 8760 or Moton 3 ways... What do you wanna know?
Old Nov 18, 2010 | 11:16 AM
tepid1's Avatar
Koni electrics, but for the rear you have to run a custom adapter to fit the long shock/spring assembly.
I've been working on this setup for a while now. Hopefully I'll get to use it next year!
Old Nov 18, 2010 | 11:22 AM
YZFR6's Avatar
Koni electrics don't have high speed bro, just rebound and compression which are seperate adjustments... The MSD box that you're using for set up controls the shock on time based or however you have it set up to soften or stiffen your shock down the track. You running the sweeps too on your set up?
Old Nov 18, 2010 | 11:39 AM
h2.4's Avatar
just looking at options for shock shaft speed sensitive adjustability. I guess I'll check those out or look into getting some custom valving. Thanks!
Old Nov 18, 2010 | 04:24 PM
tepid1's Avatar
Guess I should have read everything before I commented. lol
I'm not using a MSD to adjust anything with the shock.
bmorley
Sep 29, 2017 09:52 AM
AFAccord
Suspension & Brakes
Jun 28, 2015 05:18 PM
beanbag
Nov 6, 2008 04:37 PM
drktorn
Suspension & Brakes
May 28, 2006 06:04 PM
wuclan
13
Mar 1, 2004 05:12 AM
