bearing clearances
Old Nov 17, 2010 | 05:58 PM
LS/V-T's Avatar
Icon2 bearing clearances
when building a high horsepower(300-500whp) honda b series engine do you guys run oe spec bearing clearances on the rods and mains ?
I am rebuilding my ls/vtec (stock ls crank, eagle H beam rods). Can someone give me a link or point me in the right direction?
Old Nov 19, 2010 | 10:19 AM
fv8s's Avatar
Default Re: bearing clearances
OEM bearings will work fine. Last I heard ACL's were on a nationwide backorder. If you can find a set of ACL Race Bearings I would go with those.
Old Nov 19, 2010 | 11:24 AM
LS/V-T's Avatar
we usually run the bearings on our street/strip v8s a little loose compared to oe spec.. Is it not the same for a street/strip 4cyl honda engine??
Old Nov 23, 2010 | 07:36 AM
thread jacker's Avatar
You will want to run witihn the honda specs for bearings and follow your piston manufacture specs for bore size. I usually get all my acl race bearings off ebay.
Old Nov 23, 2010 | 01:22 PM
EG1834's Avatar
That's what I've done and it works great. Over 700whp out of a turbocharged 2.2L and no problems. Generally I'd run about .001" of clearance per 1" of journal diameter, but the big power stuff I run a few tenths looser than that.
Old Feb 5, 2011 | 01:38 AM
562SkankDC2's Avatar
bump this i need some help also???
Charlie Moua
Jan 16, 2012 07:01 PM
hondaapi
Oct 25, 2006 04:31 AM
IN VTEC
Mar 18, 2006 08:40 PM
B-B-K
Nov 9, 2005 06:39 PM
