1993 Prelude VTEC part out. Built H22a1
Old Nov 17, 2010 | 04:03 PM
ludekid4323's Avatar
Default 1993 Prelude VTEC part out. Built H22a1
Hey guys, as a lot of you know I was selling my prelude but no one had cash to buy the whole thing so now she's getting parted out. All prices are obo and you pay for shipping for everything minus the engine. Will not part that out btw. No part are off the car yet but shoot me a pm and I'll go pull it and clean it up and get it shipped out. Let me know if you want pics of specific parts. I am located in york PA and the car is in my little one car garage
4 16x7 Rota Slipstream'a 40mm offset with 2 newer 215/50/16 Dunlop direzza DZ010’s and 2 bald ones
$350
Used blank rotors, prelude VTEC calipers front and rear, and Russel stainless steel brake lines. One front line has about a 1in section that the clear plasic is worn down from lying on the axle for a short trip. Doesn't leak or let air in or anything, just cosmetic
$150
H22A1 with unknown milage. Doesnt burn oil, conservative tune. Motor is still in car, up to the buyer to come get it, dont care if you cut the whole front of the car off or what
Energy Suspension poly motor mount inserts
Explicit Speed Performance drivers side motor mount
M2A4 JDM manual transmission
Newish OEM clutch and flywheel
Brian Crower Stage II all motor cams
Brian Crower dual valve springs
Bring Crower Steel retainers
Ferrea valve seals
Unorthadox Racing adjustable cam gears
Unorthadox Racing power steering and alternator pulleys
Brand new alternator
Brand New distributor
Brand new Bosh plugs and wires
Cometic head gasket
Custom Jagermeister coolant overflow
ARP head studs
Skunk2 cam seal
Brand new OEM water pump
Brand new OEM timing belt
3-Angle valve job
Resurfaced Head
Maxbore USA 65mm throttle body and port matched intake manifold
KMS EGR blockoff plate
Custom IAT blockoff plate
Hondata intake manifold gasket
Removed IAB butterflies
4bidden motorsports cooling plate
12in FAL slimfan
AEM cold air intake with k&n cone filter
Samco Sport silicon radiator hoses
Skunk2 magnetic oil drain bolt
Inlinefour.com billet plug wire cover
Polished valve cover with moon cut around cam gears
Removed cruise control
Removed air conditioning
APC oil cap
Megan Racing header
ycunderground.com tuned p28 with ECTUNE and equipped with 3-step and anti-lag
$2300
2.5 in exhaust
Gutted cat
22in long resonator
Vibrant flat black twin tip muffler
$150 wont ship
Momo Tuner 350mm steering wheel+NRG version 2.5 quick release+NRG slim hub
$230
silver NRG rep harness bar
Red Sparco clubman 4pt harness
Sparco Torino2 seat
Sparco bracket and sliders for the seat
$500
JDMshit.com Spoon style front lip
has a few scrapes from pulling in and out of my driveway along with a few tiny holes on the top/mounting face of the lip from running zipties through my hacked up bumper
$100
Clear turn signal bumper lights
$10
SSR bumper quick releases
$20
Tanabe Sustec rear upper strut tower bar
$50
EM racing rear c-pillar bar
$120
Nameless front upper strut tower bar-hand polished
$20
Koni yellow struts
Skunk2 adjustable sleeve springs
The front passenger side strut has the c-clip weleded to the strut on the lowest of the 3 levels because it loosened up allowing the spring and perch to drop. Re-sprayed hi-temp yelow
$350
Epic FAIL fender
Old Nov 17, 2010 | 06:15 PM
Default Re: 1993 Prelude VTEC part out. Built H22a1
ttt
Old Nov 17, 2010 | 07:19 PM
NateB's Avatar
How much for just the front calipers and brackets?
Old Nov 17, 2010 | 07:57 PM
$50+s/h work? I have some relatively new hawk hps pads with them you can have too if ya'd like
Old Mar 29, 2011 | 06:48 PM
ludedude1993's Avatar
ayy so how much u want for the vtec head? lmk
Old Mar 29, 2011 | 08:07 PM
jspekaccord's Avatar
$350 shipped for wheels to 77450 with no tires? If so ill take them. please pm me.
Old Apr 5, 2011 | 07:07 PM
CoryJNason's Avatar
40 for the dizzy?? PLEASE!!!!!!
Old Apr 5, 2011 | 08:19 PM
SPOON_BeIgHtEeNsEe's Avatar
part the head?
Old Apr 6, 2011 | 11:04 AM
jarol220's Avatar
How much for your upper and lower rad hoses pm me
Old May 10, 2011 | 04:35 PM
bb4_bkh's Avatar
not parting out any of the body panels? i'm in desperate need of a passenger fender and front bumper..
Old May 10, 2011 | 04:51 PM
acidburn2k2's Avatar
are you still parting this out? Interested in the clear turn signals and bumper lights. How much shipped to 34747?
strokedb16delsol
Apr 25, 2009 04:36 PM
xTravBx
Jan 10, 2007 05:18 PM
huge230
Aug 12, 2005 12:37 PM
cookci
Apr 25, 2004 10:35 AM
