B18C1 in a CRX Header bolt up
I'm about to drop a B18C1 into my 90 CRX Si.
Does anyone know what header/ exhaust manifold would clear the oil pan and crossmember AND "bolt" up to the stock Catalytic Converter? I don't want to take it to a shop and have them weld a piece to fit it, I want it "BOLT ON."
Thanks in advance.
Thanks in advance.
x2 nothing is gonna just work and fit like stock. its an engine swap, your exhaust wasnt designed for that b series exhaust header. get creative and just have a pipe weled on. done
My setup right now for my ls is as follow:
Top Half Exhaust Manifold from a 90-91 Integra or any b-series that are 4-1.
Downpipe is my stock crx/civic downpipe with the uberly loved extension. And I really do love that extension. lol.
It should BOLT-ON.
The only modification you will have to do is keep twisting the cat around until all the holes/studs line up.
GL and post some pix!!! I would post my setup, but it is 6 am and I just got off work while still being cracked out on two tall cans of rockstar.
It should BOLT-ON.
It should BOLT-ON.
thats what i did until i was able to get an adjustable test pipe. once you have the stock cat mounted to where its gonna line up with both the exhaust manifold and the cat back then it may require some muscle to try and get all the bolts in. but, it works and should hold you off for a while.
So it looks like some combinations of downpipe and cats will bolt up!
BTW, thanks to the guys that said to have it welded I do have a mig welder and I will use it if I need to.
SantaCruz92Si
Jul 22, 2003 01:57 PM
shadowstylz
Jul 7, 2003 10:05 AM
