help with my pedal assembly clutch not working!!!!
Old Nov 17, 2010 | 11:00 AM
jesusjdm89's Avatar
Default help with my pedal assembly clutch not working!!!!
my pedal assembly broke off so i took it off welded it back i put everything back on i when to turn my car on and my clutch has pressure the tranny is opening but is not grabping and it has a new clutch pls any1's help
Old Nov 17, 2010 | 11:13 AM
FSRslug's Avatar
Default Re: help with my pedal assembly clutch not working!!!!
huh?
So your pedal assembly broke, you took it out and welded it, put it back together, and now the clutch doesn't work?
Can you get it into gear? Try with the car off. You should be able to get it into gear with the car off without using the clutch.
If you can't with the car on, I would guess your clutch cable needs to be adjusted.
Old Nov 17, 2010 | 02:37 PM
jesusjdm89's Avatar
yeah bro i turn on or off the car and my gears go in easy and there is pressure to the clutch thats what i dont understand and i cant really adjust the cable cus my cable before got streched but i fixed it with a spacer and also could it be that my the cable is way to tight
Old Nov 17, 2010 | 06:50 PM
FSRslug's Avatar
Do what you need to do so the cable tension is in proper adjustment.
92TEGGYGSR
Jul 12, 2004 04:56 AM
keVerns
Jun 28, 2004 12:20 AM
Urban Business
Apr 4, 2003 10:43 AM
Flexmyrex
Nov 30, 2002 02:36 PM
