Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
Odyssey sliding door closure motor
Old Nov 17, 2010 | 08:56 AM
DennMann89's Avatar
Default Odyssey sliding door closure motor
I have a 2003 honda odyssey that the drivers side sliding door doesnt latch completely closed. I have replaced the rollers thinking that they were bad(which they were) and creating drag on the door and closure motor, possibly not letting it close the door with full power.
Then i thought maybe the cable just needs adjustment, because the door will close then and motor shuts off but just wont latch and then I wld have to kind of shove it into latch.
Im posting this hopefully to find someone that has had this problem before and if any suggestions or comments wld be greatly appreciated.
thank you
Old Nov 20, 2010 | 01:51 PM
johnanschutz's Avatar
Default Re: Odyssey sliding door closure motor
I had the same problem. There is a motor just for the final latch. I have unjammed it in the past and it worked for a couple of years but now it has stopped again. Probably would have been better to replace the mechanism. Be sure to clean the door contacts as well. Good luck.
Ci-v-iC
Aug 17, 2013 12:26 PM
Mindless Mind
Honda Civic (2001 - 2005)
Jun 17, 2009 08:05 PM
misterdopey
Aug 24, 2008 03:26 PM
Byaaah!
Jun 2, 2007 11:33 AM
btr24evr
Aug 17, 2004 03:26 PM
