d15 Vtec swapp help
ok so i have this civic si 91 and it had some engine problems so i bought this same engine but it a vtec insted of the 16valve its a d15b1 and for some parts the swap looks easy but then there are some cables on the newwer engine that i dont know what to do with.... and some of the wireing looks like it has a few extra things..... im new to all of this all i thought i needed was a new engine and just put it in..... is there anything else i need when swapping? any help woulld be appreciated and if your seling parts m interested in checking them out
You are using the stock harness correct? The wiring differences are as follows:
-injectors, use the SI for plug and play
-if you use the P28 ecu and go obd1 you'll need the D15b/d16z6 distributor and an adapter harness or need to repon the dizzy
-fan switch wiring from the back of the block to the new motors thermostat housing
-the fast idle on the back of the Si motor will not be used anymore
-wire up 4 wire 02
-vtec solenoid and vtec pressure switch wiring
-wire up 4 wire 02
yea i can comprehend som what but i need a list on what to do and what i need to get new so ty for the anyfo anmore would be great.. im just ganna either send this motor back or sell this hole package
Its pretty simple. Just take the intake manifold off the eninge that ur replacing. Then put it on the replacement engine. Then ull have to modify ur distributor a lil for it to fit. Google "a6 dizzy on a z6 head" and u will find pics detailing the procedure
did you figure it out yet?... im new to honda tech but i have done b20s, ls, and many singlecams vtec and non...if you have the si wire harness off the car u still will have to wire up vtec still... and have to get a new ecu if u want vtec... u can use the same intake like efjones said and you will have to go into ur ecu harness to pin out vtec, you can find the vtec pinouts on google images... message me if u have anymore qwestions
this swap is easy i did a z6 swap in my 89 ef twice you gota know first if your goin to go obd1 or keep it obd0 then you will know what exactly u need to modify like dizzy, injectors, or ecu hit me up if u need help and u have to also change your driver side mount depending what car that motor was in
