Clean 2001 Acura Integra GS-R
SOLDDD
RARE 2001 GSR, Only Year to Produce GSR's in Silver.
NO TRADES, Buying a new car and can't have two! 845-206-1071. $5,500
BUMP if viewed Thanks! Ill make a deal with you...Bring your own wheels and the LOWEST ill go id $5,000 and it's yours.
~Clean Titled 2nd owner 2001 Acura Integra GS-R, (151,000 Miles), Jdm B18c Engine With receipts from JDM Engine Depot (65-75k Miles) Has170 hp @ 7600 rpm, 128 lb·ft @ 6200 rpm , Redline: 8100 rpm 2 stage VTEC Engagement @ 4400 rpm + @ 5900 rpm, Transmission: Y80(No LSD) 5-Speed Manual (151,000miles) Very smooth Just changed the fluid.
~(less than 5k Miles since swap, All completed June 2010)...
~All Fluids flushed and replaced, Everything works Great. No check Engine lights have ever been on since the since the installation, CFK ECU trick was done to the usdm ecu to prevent a check engine light coming on for the lack of a crank fluctuation sensor on JDM engines. Passed NYS inspection with no issues in July 2010.
~Full tune up All New spark plugs, wires, distributor rotor and cap, Pcv valve, all new exhaust gaskets, TB gasket and Intake manifold gasket.
~Exedy OEM Clutch and 9lb. Flywheel kit
~AEM intake
~New O2 sensors installed Upstream and Downstream ($300+)
~16" Carbon Fiber Rota Boosts with 2009 Gunmetal HONDA Center Caps, Has new front tires.
~Skunk2 adjustable control arms with brand new balljoints, Lowered 1 1/2" in the rear, and 2" in the front. Rides nice and smooth.
~Integra Type R replica front lip painted
~Stock Exhaust system and muffler (Quiet), Have a brand new uninstalled midsection/midpipe that is included
~Brand new Windshield and moldings installed in september 2010
~Excellent condition Black Leather Interior, Kenwood CD + Ipod hookup, Completely wired for a system. Also has A/c and Power steering installed
for larger pictures: http://s828.photobucket.com/albums/z...Integra%20GSR/
Bad:
Driver window is slow rolling down, and there is some small surface rust spots starting on the lower section of the passenger door/ and drivers mirror the paint is peeling, and could use new rear tires.
~AEM intake
Bad:
damn i really want this. i wish you posted this up when i was trying to move into a gsr before i would have brought it cash.. wish i could sell my teg fast enough to buy this. darn.
1player2nv1
Dec 18, 2010 09:57 AM
