Buddyclub N+ damper adjustment for EK?
I have searched but cannot seem to find exactly where i have to adjust the damper. I would assume you have to adjust damper from the top from the engine bay. I want to know the correct way to adjust damper. Please help me out this is for a 1996 civic and i didnt buy the suspension new. Hence i have no owners manual.
Pics will be appreciated!
Thanks logz! ill be picking some up in a couple days, one other question i had was its 15 way adjustable. When you turn the small dial you should hear clicks, but my question is when do you know when its back to setting #1?
Yes, you will hear/feel a click. You need to turn the dial all the way counterclockwise till it stops to be at the #1(softest) setting. Don't be surprised if you can get 16 clicks, as that is perfectly normal.
one last question. when putting these on what setting should i have these on? i know i must preload the suspension but just wanna make sure i dont mess anything up by having it set at 5 clicks front 7 clicks rear
jdmmugeneg6
24
Oct 16, 2004 09:32 AM
adjust, adjusting, adjustment, buddy, buddyclub, cars, civic, clockwisr, club, counter, damper, ek, instructions, n, suspension
