Will this seat cutter work on honda/acura heads?
Old Nov 16, 2010 | 09:20 PM
jdmcivic2fast's Avatar
Default Will this seat cutter work on honda/acura heads?
The profile is from Newen, its for the Exhaust side.
# Delta X Length X Angle
1- Delta 00.26mm/ Lenght 02.00mm/ Angle 82.50
2- Delta 00.67mm/ Lenght 01.75mm/ Angle 67.50
3- Delta 00.20mm/ Lenght 00.40mm/ Angle 60.00
4- Delta 00.24mm/ Lenght 00.40mm/ Angle 52.50
5- Delta 00.71mm/ Lenght 01.00mm/ Angle 45.00
6- Delta 00.35mm/ Lenght 00.40mm/ Angle 30.00
7- Delta 00.77mm/ Lenght 00.80mm/ Angle 15.00
8- 01.48mm/ 15.00 94.00 02.00mm Radius
if it works, does it have to be on a new seat or this can overcut the factory seat? thanks
Old Nov 17, 2010 | 01:55 PM
Combustion Contraption's Avatar
Default Re: Will this seat cutter work on honda/acura heads?
Define "work".
Old Nov 17, 2010 | 02:34 PM
Originally Posted by Combustion Contraption
Define "work".
"work"
I guess what im asking is
will the cutter be able to cut all the angles on the honda heads without messing up?
Old Nov 17, 2010 | 02:58 PM
Depends where the machinist places the 45 on the valve/seat. I wouldnt use that cutter.
Old Nov 17, 2010 | 06:07 PM
092eg6's Avatar
too many angles??
Old Nov 18, 2010 | 11:49 AM
what do u mean by placing the 45 on valve/seat??
the cutter has all the angles made onto it, so wouldn't the 45 on valve and seat match up?
Old Nov 18, 2010 | 04:31 PM
Do some reading on the subject of valve jobs and you will understand better. This is really basic stuff, and if you really want to know the answer to the question you're asking, you'll have to get the basics down first. Walk before you run sort of thing.
And if you don't feel like reading up and would just rather pay someone to do it, that's fine too, just don't second guess their work when you don't understand it yourself. (Not directed solely at you, just something I have seen way too many times.)
Old Nov 18, 2010 | 06:14 PM
wel obviously im letting my machinist do the job but he only carries standard rebuild type cutters, im trying to figure out a custom cutter for the seats, im sure the 45* seat is still gonna be where the factory 45* was but just a little thinner on the width.
petrez
Aug 12, 2018 06:42 PM
massakalis56
Sep 16, 2017 12:41 PM
IP RACING
14
Feb 26, 2009 10:42 PM
EFin' Kyle
May 20, 2005 12:02 PM
