timing belt, waterpump, and oil pump change?
Old Nov 16, 2010 | 07:08 PM
770_dc2's Avatar
Default timing belt, waterpump, and oil pump change?
ok so im about to do a timing belt, waterpump, and oil pump change on my 96 integra ls and im just wondering if i should go with the ls kit or the gsr/type r kit? my car is all stock and just wondering if it would b better to run these gsr/type r parts in my stock ls? need some advice b4 i puschase these parts
Old Nov 16, 2010 | 07:29 PM
JDM215's Avatar
Default Re: timing belt, waterpump, and oil pump change?
no, type r gsr parts on an ls is not needed unless your doing an lsvtec
Old Nov 17, 2010 | 10:49 AM
fv8s's Avatar
I was reading through a thread a while back and someone actually proved that the LS water pump flowed better. On any LSV build/ VTEC build you will need the ITR/GsR pumps.
Old Nov 17, 2010 | 12:21 PM
lsturbo33's Avatar
I believe you already have the same oil pump. 96+ ls use the same oil pump as the gsr/type r. If you want to use a 22t water pump be sure to use the gsr/type r belt.
Old Nov 17, 2010 | 04:17 PM
770_dc2's Avatar
ok thanks guys guess ima just get the ls one
deemy72
Jul 9, 2009 10:20 AM
KdF
Mar 10, 2009 05:36 PM
Justintegra
Apr 20, 2008 12:46 PM
Youlose1305
19
Jul 9, 2006 09:53 AM
95lsteg
Dec 9, 2003 11:50 AM
