Timming question car is missing after T-belt??
Old Sep 21, 2002 | 08:01 PM
-=TWITCH=-'s Avatar
Default Timming question car is missing after T-belt??
I have some questions for you guys. I used to be a reg on this board but sadly sold my civic. I now have a Talon TSI, I wanted to ask here a H-T because I think you guys know your ****. Plus the mitsu boards are just filled with Rice and I dont want to waste my time . OK now onto the question. I just did the timming belt on my car everything went fine, but the car is missing now. I thought it might be plugs or wires So I replaced both still misses. So I did my homework, and im thinking my exhaust cam might be off a tooth? could I just pull off my cam cover and check the marks at TDC and if they align its correct? Would I have to take everything back apart and check the crank? I understand how it works, I just dont understand How to check to see if I have slipped. If the exhaust side is off then wouldn't it just show on the timming marks at TDC thanks alot for helping a fellow H-T member out
Old Sep 21, 2002 | 09:26 PM
-=TWITCH=-'s Avatar
Default Re: Timming question car is missing after T-belt?? (-=TWITCH=-)
anyone wanna help me out?
Old Sep 22, 2002 | 06:23 AM
Mikey3000's Avatar
turn the crank by hand and put #1 at TDC and check if the arrows on your cam gears are pointing straight up, or are aligned correctly. i don't know if mistu's have arrows like hondas.
B18EG6
Jan 13, 2006 11:02 AM
SiR Vtec X
Oct 12, 2005 07:04 PM
dayaftertomorrow
Feb 12, 2005 06:13 PM
HamiltonRex
Nov 14, 2004 04:00 PM
LX4CYL
Oct 10, 2004 06:48 PM
