high hp clutch line question
Old Nov 16, 2010 | 04:33 PM
H23vtecEF's Avatar
Default high hp clutch line question
I am turboing my EF this winter and i am wondering if any of the higher hp guys switch from the cable clutch line to hydro? I have a comp clutch stage 4 clutch and i just snapped my clutch cable after just a year of dd it, and i dont want to keep replacing it every year. It was brand new from honda when i swapped the motor. If you guys keep the cable is there a better alternative to oem? or should i just go hydro
Old Nov 16, 2010 | 05:07 PM
J. Mills's Avatar
Default Re: high hp clutch line question
Forget the cable and go hydro. I kept braking cables and pedals.
Skip the cable to hydro conversions and just convert the whole car over to hydraulic using a master and all.
Old Nov 16, 2010 | 05:13 PM
Blown90hatcH's Avatar
+1
Old Nov 16, 2010 | 05:25 PM
xenocron's Avatar
+2
Old Nov 16, 2010 | 05:38 PM
jdm inc's Avatar
+3
H23vtecEF's Avatar
if i convert everything over do i have to change the pedal too, and if so what pedal do i use? anything 92+? how come you guys dont like the cable to hydro conversions?
xenocron where in ny is hillburn? im in the cap. district
Old Nov 16, 2010 | 05:41 PM
Mr. Em1's Avatar
x4.
hillburn is located near suffern about 5 minutes from the nj border.
usually you use an oem pedal and modify it and the firewall to make it work right. the cable hydro kits arent very reliable and look like **** too. its worth the extra time and money to convert it.
Old Nov 16, 2010 | 05:59 PM
H23vtecEF's Avatar
thanks for the info, i guess i will start shopping for parts lol at least the tranny was originally a hydro. is there a difference between civic and teg setups, like does one push more fluid or is stronger than another?
Old Nov 16, 2010 | 06:06 PM
xenocron's Avatar
Yeah EG pedal, EG slave, reservoir and a line...
I had Albert @ Certified Racing do mine...unless you want to do it yourself (I didn't) they could certainly help you out at a decent price.
Old Nov 16, 2010 | 06:42 PM
H23vtecEF's Avatar
do you know if anyone has a write up about this, i cant seem to find anything in search or in the ef/crx faq's either
J. Mills's Avatar
For my CRX i used a CRX pedal assembly. I modified it to hold a 92-95 civic master cylinder under the dash. Braided line from the master cylinder to the slave. My reservoir is on the firewall under the hood. The only cost i had in the conversion was for a new master. Everything else i had laying around the shop
Old Nov 16, 2010 | 06:45 PM
J. Mills's Avatar
I didn't know they made it then, but i made something identical to whats in this thread
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/sonem-ef-bolt-hydraulic-clutch-conversion-2472947/
Old Nov 16, 2010 | 07:20 PM
H23vtecEF's Avatar
thanks, great info
jonnyt1130
10
Jun 1, 2010 09:51 PM
90civic1.5
Feb 17, 2010 09:29 PM
MooreBoost
33
Jun 30, 2004 05:18 PM
