Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
question on brakes
Old Nov 16, 2010 | 02:27 AM
jdm3nt's Avatar
Default question on brakes
when pressing on brake it has this weird grindy feeling, but it disappear after awhile...did anyone had experince with this ?
Old Nov 16, 2010 | 02:29 AM
darath's Avatar
Default Re: question on brakes
Same here. I can hear mine coming from the rear driver side. Don't know what's wrong, but I checked the pads n they're good.
Old Nov 16, 2010 | 05:05 AM
phatEg18c's Avatar
what the models of cars
Old Nov 16, 2010 | 05:20 AM
na+b18c_hatch's Avatar
could just be surface rust, which will build up overnight. this is normal and nothing to worry about.
Old Nov 16, 2010 | 07:11 AM
GoLowDrew's Avatar
Old Member
25 Year Member
^^^ more so during the winter with the extra moisture in the air.
Old Nov 16, 2010 | 10:10 AM
bee guz's Avatar
I would check the pads, make sure you get a good look at how much lining there is on the inside or inboard pad, the outer pad can look good and the inner will be worn thin or out.
If it is just the over night rust on the rotor issue fine, but if it is the pads worn out catch it before it ruins the rotor costing you more.
Old Nov 22, 2010 | 03:34 PM
jdm3nt's Avatar
thnks guys for da advice....
Old Nov 22, 2010 | 06:08 PM
meetyoutoday's Avatar
that's true for sure.
jjohn6438
Honda Civic (2001 - 2005)
32
May 11, 2009 05:43 PM
mrdeadman
Aug 3, 2005 07:28 AM
Poopie
Jun 25, 2004 07:03 PM
metal-x
Jul 20, 2002 05:53 PM
95GS-R
Mar 6, 2002 05:56 AM
