jdm itr front end conversion hood latch problem
Old Nov 15, 2010 | 08:26 PM
skyline999's Avatar
Icon6 jdm itr front end conversion hood latch problem
hey guys i just did a jdm front end swap on my 2001 ls. im having problems with the hood latch the jdm one runs to the passengers side but the line was cut and the usdm hood latch doesnt work because it goes on the inside of the rad support but the old line isnt long enough either. i was wondering if anyone else ran into this problem and if they did what did you do?
Old Nov 15, 2010 | 08:44 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: jdm itr front end conversion
use the jdm one and get yourself a da hood cable and run it just like the usdm factory. Or for now use the jdm and extend the cut latch and open it thru the bumper
Old Nov 16, 2010 | 02:56 AM
Acura98guy's Avatar
As Soft As A Rock
Or you can buy a DA hood latch.. use a USDM cable. I have da latch laying around that I will let go for cheap. Or just use the stock latch.. that runs to the passenger side and relocate it ( help people from stealing your car..)
Old Nov 16, 2010 | 05:53 PM
skyline999's Avatar
i was thinking bout doing that but then i have to drill a hole through the fire wall but i think thats what im going to do, thanks guys. also i was wondering about the head light harness, its different than the usdm one and i dont want to splice wires because im afraid of a possible engine fire. i have seen a harness on password jdm specificly for that but they dont have it in stock and dont know when there getting another one in, does anyone have other ideas on what to do or another place to get that harness that incorporates the running lights, blinkers, and side makrers?
Old Nov 16, 2010 | 07:28 PM
95-db6-719's Avatar
the usdm latch and the jdm latch are exactly the same, the way the bolt to the t bracket is just different. usdm one is flip flop and bolts to the inside on the t bracket, and the jdm one bolts to the front of the t bracket.
i extended the usdm line and just looped it around to the passenger side, from the driver side, put a sheet metal screw with a line clamp on the extended cable..
thats how i did my last one, cause i was on a major budget.
Old Nov 17, 2010 | 03:17 AM
Acura98guy's Avatar
As Soft As A Rock
Get these.. idk if your on a budget.. but these are honestly the EASIEST way to do the lights. ( fog light will require a switch.. but you can hook them up to running lights or w.e lights you want.. but i rather have the ability to turn them on/off when I want.)
http://passwordjdm.com/PasswordJDM-C...P1008C320.aspx
http://passwordjdm.com/PasswordJDM-H...P1769C320.aspx
Then just splice the wires according to this diagram..
https://honda-tech.com/forums/lighting-107/how-jdm-itr-hid-headlight-fog-light-wiring-2195061/
( might be wrong.. i can not see the pictures on work computer)
or just use these but they are not always effective if you don't do it right...
http://www.wiringproducts.com/contents/en-us/d266.html
you can get these at any walmart or autzone or ma-pa store.
Hope this helps.
Old Nov 17, 2010 | 03:47 AM
Lugzilla's Avatar
Canuckian
Hope this helps.
Don't waste your money on that stuff. Seriously, pick yourself up a soldering iron and shrink wrap. As long as your connections are good you'll have no worries.
Old Nov 17, 2010 | 05:58 AM
JDM 98 GSR's Avatar
that password harness are such a huge waste of money..i learned that the hard way
Old Nov 17, 2010 | 06:27 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: jdm itr front end conversion hood latch problem
Thread title edited to be more descriptive of the actual problem.
Old Nov 17, 2010 | 12:41 PM
skyline999's Avatar
why is that?
Old Nov 17, 2010 | 01:20 PM
jaykerp92eg6's Avatar
I ran into this problem when I did the front end on my 4dr and I used all the JDM parts and used a cable for a crx hatch relese it was a little long but i routed it along the rad support and it works perfectly fine. I hope this helps, I just used what I had laying around in the garage
Old Nov 17, 2010 | 09:22 PM
JDM 98 GSR's Avatar
why is that?
well atleast if you have HID headlights..and when i called password and asked if if works for them also they said "yeah its a plug and play harness for HID headlights also" which its not..i just wired them myself and im much happier..
jdmdc5integra
Aug 2, 2014 05:35 PM
teamkosmos
Oct 3, 2012 11:29 AM
llama003
Feb 18, 2007 07:24 PM
sikciv666
Jul 7, 2004 09:05 PM
byatchplzzz
Jul 25, 2002 03:51 PM
