Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Help! 2003 passanger window problems
Old Nov 15, 2010 | 05:34 PM
miguel1313's Avatar
Icon3 Help! 2003 passanger window problems
Hey guys! first time poster here, long time lurker. I have always been able to solve my problems from other posts but had no luck searching on this one.
My passenger window will not go up or down using either switch. However, the window does go down when I use the unlock button on the remote (I did it multiple times on the way down while I attempted to make it go back up). This leads me to believe it's an issue in one or both of the switches because the motor is working correctly in bringing the window down. I checked the fuses and the relay under the hood and they are both okay.
So my question to you all is 1) has anyone ever heard of this? and 2) does anyone know where I should start to remedy this? I am up in New England and it's getting cold not to mention rain in the forecast!
Old Nov 16, 2010 | 02:49 AM
miguel1313's Avatar
Default Re: Help! 2003 passanger window problems
BUMP for rain in the forecast
Old Nov 16, 2010 | 05:01 AM
phatEg18c's Avatar
what kind of vehicle is it? have you check power at the master window switch and the pass. switch? lmk
Old Nov 16, 2010 | 06:49 AM
miguel1313's Avatar
03 Accord coupe V6 - I have not checked power no.
Would both switches be connected to each other? ie one switch going bad would cause the other not to work as well?
What is my best method to check power? I do have a pen type meter that detects current at an electrical box, would that work in a car as well?
Old Nov 16, 2010 | 04:08 PM
miguel1313's Avatar
What do you mean by "check the switches" ? I have both doors apart...
Old Nov 17, 2010 | 03:58 PM
BLKFLSH's Avatar
Use the test light to check for power going to the switches, and power from the switches to the window motor when activated. Obviously the motor works, so you need to work back from there, to the point where power to the motor stops.
ghost220
Jun 14, 2015 04:20 AM
bassichonda96
Jun 22, 2009 05:37 AM
drew and not u
Jun 28, 2008 06:56 PM
Siegfried
Nov 25, 2004 12:13 AM
Leets
Jan 3, 2003 12:13 AM
