spark flame front speed
Old Nov 15, 2010 | 05:11 PM
cj011's Avatar
Default spark flame front speed
The subject pretty much says it all. I am putting together my spark table for MS and I already have down the time it's take for revolutions per given rpm. Regarding the spark flame speed during combustion, I have seen alot of conflicting info and nothing out there that goes into how its found.
I appreciate the help....
Old Nov 16, 2010 | 02:32 AM
Tony the Tiger's Avatar
Default Re: spark flame front speed
Good luck on finding that info...
Just by going with a different bore size, or a different heat range spark plug, would throw that number around big time. I don't even think there is a method you can find this "value" if that is what you are looking for in order to dial in the spark timing.
Old Nov 16, 2010 | 08:35 AM
unusual71's Avatar
why do you need to know the flame front speed? only needs to be looked at when you are approacing huge piston speeds (>6000 ft/s) IMO. otherwise ignition can be calculated comparatively against stock/other setups and will need to be optimised on a dyno.
Old Nov 16, 2010 | 10:38 AM
sander's Avatar
2.7(p/t)
It's not a relevant data point. What your asking is dependent on too many variables beyond actual timing. Why do you want that information?
Old Nov 16, 2010 | 03:43 PM
cj011's Avatar
coming up with an initial spark map for MS. Also, I want to target a specific crank angle for ignition timing wise. Yes I know that I can go with a stock spark table, but this is for future reference. I already have it down to figure out the time is m/s how many degrees the crank will travel or how long a degree will take. In regards to the bore size, I would take the bore and size divide by 2. That should compensate for the any size difference, the problem is that I don't have a rule of thumb to go by for the spark flame front. I am find everything from 880 inches/second to 1 meter/second. I do know that the air/fuel ratio comes into to play, but as to what extent I am in the dark about.
Brandi18c1
Dec 13, 2012 09:21 PM
crashsvg
Engine Management and Tuning
Oct 14, 2011 09:26 AM
Glove
Jun 16, 2010 10:44 AM
the.hamburglar
Jul 7, 2005 09:36 PM
mickey513
May 16, 2004 01:11 PM
