Hatchback headlight question.
Old Nov 15, 2010 | 01:08 PM
EFR's Avatar
EFR
Default Hatchback headlight question.
Hey HT,
Going to get some HIDS for my headlights. I know that the low beam is 9006 and the high beam is 9005, so my question is which bulb is which? 9005 for the inner part and 9006 for the outer part of the headlight or vice versa? Someone please help me out.
Thanks alot !
Old Nov 15, 2010 | 01:12 PM
miguey310's Avatar
Default Re: Hatchback headlight question.
what's your question? it's hard to understand what your writing
Old Nov 15, 2010 | 01:23 PM
EFR's Avatar
EFR
I guess what I'm trying to say is what bulb goes into what socket? cause there's two sockets in each headlight so I wanted to know which one is 9005 & 9006.
Old Nov 15, 2010 | 01:32 PM
miguey310's Avatar
are you planning to do high and low beams ? and each bulb has different sockets
Old Nov 15, 2010 | 01:41 PM
tyked15's Avatar
the outside bulb is low beam an the inside bulb is high beam
Old Nov 16, 2010 | 12:07 AM
Fo-Do Fanatic's Avatar
Your regular lights, low beam, are 9006's. When you look at the part the clip goes into you'll see one line that sticks up. You high beams are 9005's, when you pull your healight leaver towards you and it clicks and your highs comeon. When you look at those bulbs they have two lines that stick up. They do that so you wont put the wrong bulb in the wrong socket. Safty feature.
TurtlePoopers
Feb 2, 2017 05:08 PM
unclematt
Sep 1, 2016 09:39 AM
naz0o
Honda Civic (2006 - 2015)
Aug 19, 2008 09:46 AM
bopbop93030
Feb 8, 2008 11:02 AM
