D16Y8 - Timing belt replacement?
Old Nov 15, 2010 | 10:39 AM
ManicMike's Avatar
Default D16Y8 - Timing belt replacement?
Met a new friend the other night and I wanted him to double check the ignition timing since I just replaced the distributor. Well, long story short he wasn't able to time it perfectly since the belt jumped a 1/2 a tooth or 1 tooth.
The motor has around 90k on it, so i figure it's time to replace the few parts anyways (timing belt, water pump and tensioner).
He told me just go OEM and hondaautomotiveparts.com would be the best to order from online.
Problem is, I don't know which parts to order. I saw two diffrent belts to pick from and wasn't sure which to get. Also saw like 3 diffrent tensioner's.
Just trying to figure out which is the correct stuff so I only have to order it once!
-Mike
Old Nov 15, 2010 | 10:48 AM
SeanK325's Avatar
Default Re: D16Y8 - Timing belt replacement?
Gates TCK224 Timing Belt Component Kit is $40 (free ship) from amazon.com. It's the timing belt and the tensioner in one set. I'm running it on a B16A2. Gates is just as good as OEM and you can't beat that price.
Old Nov 15, 2010 | 10:55 AM
Former User's Avatar
-Mike
Did you enter your VIN at the Majestic Honda site? If so, do a screen capture of the parts lists so that we can see the options you are describing.
Old Nov 15, 2010 | 11:11 AM
ManicMike's Avatar
Nah, I don't have a VIN to go by. It's not the original engine in the car, came from a '97 civic ex. I think I read somewhere the VIN is on the engine too, so I guess I could look for it and use it on mejestic's site.
Old Nov 15, 2010 | 11:13 AM
ManicMike's Avatar
Ok that sounds great, you sure that one will work with the d16y8?
Old Nov 15, 2010 | 11:27 AM
94EG8's Avatar
Seagull Management
As far as the belt goes Gates is OEM. The last timing belt I bought from Honda actually had both the Gates logo and the Honda logo on it.
Old Nov 15, 2010 | 11:43 AM
fv8s's Avatar
I have never heard of a timing belt jumping a half a tooth?
Old Nov 15, 2010 | 12:00 PM
B18C5-EH2's Avatar
Former Moderator
Loved
If it's my car, and I'm doing a timing belt I'd replace the following - OEM part numbers are listed, along with who makes them for Honda and alternative makes that are good.
Timing belt - 14400-P2F-A01
Unitta makes the actual Honda branded belt for the 96-00 Civic EX. Other great alternatives are Gates, Bando, or Mitsuboshi. Any of these should be readily available even at generic parts stores, so please don't buy some crap Goodyear or other truly off brand T-belt. Gates does supply Honda with some timing belts too.
Alternator belt - 31110-P2A-004 (4PK800)
Mitsuboshi or Bando makes the OEM Honda belt here. Either can be found easily enough, and cheaply enough.
A/C belt (if applicable) - 38920-P2A-003 (4PK820)
P/S belt (if applicable) - 56992-P2A-003 (4PK850)
Water pump - 19200-P2A-A01
This is the tricky one. Otsugi makes the actual genuine Honda waterpumps, and they are an unknown brand amongst the local parts store types. I' have seen a lot of different brand water pumps, and the closest thing to the Genuine Honda/Otsugi water pump is the Paraut or Aisin brands, and nothing else.
Cam seal - 91213-P2F-A01
NOK or Arai Seisakusho makes the Genuine Honda seals. Do not get aftermarket brand seals. I'd score these from your local Honda dealership if you cannot find them online.
Crank seal - 91212-P2F-A01
Timing belt tensioner - 14520-P2A-305
NSK makes the Genuine Honda tensioner here. They can be found cheaply enough online at just under $20.00. I'd steer clear of other brands if possible.
Coolant (kind of impossible not to change since it all comes out when you pop the water pump off the block)
You can search Majestic Honda's site using the provided part numbers as they are correct for a 1997 Civic EX with D16Y8 engine. The only differences would be the P/S belt (if you have it) depending on what pump you're using. Everything else should be the same, regardless of the chassis.
Old Nov 15, 2010 | 12:10 PM
B18C5-EH2's Avatar
Former Moderator
Loved
BTW here are some helpful diagrams for you.
Timing marks to check timing belt timing:
Timing marks at crank gear (with crank pulley removed)
Close up of cam gear timing marks:
Timing components:
Proper timing belt routing:
Old Nov 15, 2010 | 01:44 PM
ManicMike's Avatar
Wow! Thanks for that.
I called the dealer earlier this morning and the prices where crazy, the water pump and tensioner where around $90 a piece.
Old Nov 15, 2010 | 02:17 PM
Kista20's Avatar
I just ordererd the timing belt, water pump, tensioner, etc... and all the gaskets and seals for my y5 and I went through the dealer because the parts manager gives me wholesale prices and is actually quite comparable to majestic's but without the shipping. Well last time I spent just over $400 and he turned it over to one of the other guys... needless to say in the end I didn't get a discount and could've saved $120 and had paid the shipping from majestic... never again.
the shipping is kinda high so when I order I usually try to make it worthwhile and order more than just a couple of items.
the dealer did give me wholesale prices so I can fix my front end on two fenders, bumper cover, bumper reinforcement bar, headlight, fender liner & clips and they did really good that time for me. I've prob. spent at least $1500 there just this year in parts, I never got service there unless it was still under warranty.
Old Nov 15, 2010 | 05:52 PM
SeanK325's Avatar
Yeah and you can verify it on amazon.com before you buy it. Tck227 was for my b16a and 224 is the y8. But again, verify before buying.
Old Nov 15, 2010 | 05:59 PM
SeanK325's Avatar
You should buy the OEM water pump. I paid 80 for mine. 90 isn't far off. They might give a discount for AAA members and call other dealers.
Old Nov 15, 2010 | 06:02 PM
SeanK325's Avatar
you're not the first to tell me that. Sounds good.
I fully trust gates in all its applications.
Old Nov 15, 2010 | 08:47 PM
ManicMike's Avatar
Well even if I get just the pump from majestic i'm still saving money with the added cost for shipping.
Old Nov 15, 2010 | 08:57 PM
ManicMike's Avatar
Just ordered the parts from Majestic and Amazon.
Thanks guys!
imadigitalgod
Aug 18, 2023 08:01 PM
imadigitalgod
Oct 15, 2004 09:07 PM
PetroGuyX
Jul 30, 2003 12:29 PM
jjaeschke2
Apr 7, 2003 11:05 AM
