94 civic dx idle issue?
Old Nov 15, 2010 | 10:03 AM
kevpple's Avatar
Default 94 civic dx idle issue?
my 94 civic dx coupe likes to idle @ an unusually high rpm @ above 2300 in park like its always cold even when the engine has warmed up and when its in drive it idles @ 2000 when my foot is on the brake and when i let off the brake it starts slowly accelerating all the way up into to 3rd gear on flat ground without me ever touching the gas i have checked the pedal and the throttle cable and it moves just fine. does everybody else civic do this or just mine
Old Nov 15, 2010 | 10:06 AM
Former User's Avatar
Default Re: 94 civic dx idle issue?
With the engine idling, if you cover the top of the throttle body with your hand or something else, does the engine die?
Old Nov 15, 2010 | 01:56 PM
habib's Avatar
Did someone adjust your idle screw?
Old Nov 16, 2010 | 05:53 AM
kevpple's Avatar
Put my hand on the throttle body nothing but It does die shortly after starting but that's cause the main relay right
mattf22b1
13
May 4, 2014 01:26 AM
dingusjt
May 13, 2003 10:12 AM
90CIVICSI
Mar 5, 2003 11:30 AM
