Would a b18a1 be a good swap in my 97 Civic Dx?
Old Nov 15, 2010 | 05:26 AM
D.Shizz's Avatar
Icon2 Would a b18a1 be a good swap in my 97 Civic Dx?
Would a b18a1 be a good swap in my 97 Honda Civic Dx?
Old Nov 15, 2010 | 05:37 AM
D.Shizz's Avatar
Default Re: b18a1
and if I bought a integra with everything in it, could i just swap over the ecu from the integra and everything along with the motor and tranny?
Old Nov 15, 2010 | 06:27 AM
itsnotfast's Avatar
Default Re: Would a b18a1 be a good swap in my 97 Civic Dx?
Sure.. It all depends on what your doing with the car, your preference. No you can't just swap the ECU. From what i'm gathering here. You have a 90-92 Integra which are OBD0 and OBD1, your car is OBD2A. You'll need a jumper harness. You will also need 99-00 Civic SI reat T-bracket and driver side engine mount brcket. Your harness will need some extending and you will need to swap injector pugs from the Integra harness to yours. The transmission will also need a aftermarket mount on top as its a cable trans and you will need to do a cable to hydro conversion. You'll also need a OBD2A LS distributor.
Old Nov 15, 2010 | 09:04 AM
D.Shizz's Avatar
ok thank you, sounds more expensive than i thought lol
Old Nov 15, 2010 | 09:07 AM
habib's Avatar
What is your budget for the swap, it actually is not very expensive
Old Nov 15, 2010 | 09:22 AM
D.Shizz's Avatar
well its gonna be 800 for the integra with everything in it, so ill prolly be willing to spend 200-500 over that. . .
Old Nov 15, 2010 | 09:25 AM
D.Shizz's Avatar
i just wanna get some bang for my buck, i dont wanna spend all that if goin from my d16y7 to the b18a1 wont make a big enough difference
Old Nov 15, 2010 | 09:27 AM
habib's Avatar
Take everything out of the integra you need for the swap then part out the shell or sell it whole and there is your extra cash for the swap components you will need.
Is it a cable tranny or hydro
Rear t bracket - $65 new from majestic honda
Mounts needed - $100 or so from user on h-t
Jumper harness - $100 or so
Old Nov 15, 2010 | 09:30 AM
D.Shizz's Avatar
not to bad, alright then thank you
Kungfoohippo
Jun 15, 2016 01:42 PM
B18C1 '96 Coupe
Jan 1, 2003 05:13 PM
blayzenazn
Feb 3, 2002 07:36 PM
