WTF..................
Old Sep 21, 2002 | 05:33 PM
civicrtype's Avatar
Default WTF..................
Hey wassup fellas, I just got a 89 Civic HB and it has a 93 dx engine in it. The speedo and the fuel gauge does not work? Any Ideas.
Old Sep 21, 2002 | 05:46 PM
kranked91dx's Avatar
Default Re: WTF.................. (civicrtype)
if you kept the same trany, proly just need a new cable for the speedo,
for the fuel gage run test the wire and you'l be fine to see where the problem is,
only tree solution I see here, Wiring, Gage, or in thank float.
Old Sep 21, 2002 | 05:50 PM
civicrtype's Avatar
Default Re: WTF.................. (kranked91dx)
Thanks. I'll check that out.
Old Sep 21, 2002 | 07:44 PM
Giuseppe's Avatar
u need the cable VSS..
on that 93 tranny OR.... if its your tranny connect up the VSS cable ( its a simple fix)
Old Sep 21, 2002 | 08:29 PM
civicrtype's Avatar
Default Re: WTF.................. (Giuseppe)
where is this located and how do i do this?
Old Sep 21, 2002 | 08:33 PM
Giuseppe's Avatar
the VSS is located on the top of your tranny
if its your original tranny its a cable VSS and it could possibly be
that the cable isnt plugged in..or isnt plugged in correctly..
if you have the 93 dx tranny it comes with a electrinic VSS and you have to
change that out for the cable VSS for your speedo to worl
good luck!
Old Sep 21, 2002 | 08:39 PM
civicrtype's Avatar
Thanks, you are one of the few people that have been able to answer my ?s
Old Sep 21, 2002 | 08:55 PM
B18Arex's Avatar
damn dude, sounds like my car, i got a 88 HB DX with a 94 DX motor in iot and my gas guage and my temp. guage dont work, but ive been too lazy to figure out what the problem was, and nobody knew so i didnt mess with it but im sure if you ran a test wire you could figure it out, then you have to get a speedo cable that is for the tranny you have i dont think stock will fit
Old Sep 21, 2002 | 08:58 PM
civicrtype's Avatar
Default Re: WTF.................. (1DuMpEdHB)
I know, bad luck we got huh? Lol well i'll be checking it tomorrow so I'll let you know how it goes. One!
Quada
Transmission & Drivetrain
Feb 2, 2010 03:27 PM
