d15b7 swap.Idle hunt.Help!!
Old Nov 15, 2010 | 03:53 AM
cjw_89's Avatar
Default d15b7 swap.Idle hunt.Help!!
i previously had a 1.8 in my 94 coupe but swapped out to a stock b7 auto.Now that the engine is in i have some idling issues.So i decided to remove the tb and iacv off the 1.8 engine in hopes that would solve my problem.But nope still no luck.Could there still be air in mysystem from the engine swap.If i was to top the rad up(assuming it was low) would that make it go away.It is getting to be an annoyance!!Thanks in advance!!
Old Nov 15, 2010 | 05:12 AM
Former User's Avatar
Default Re: d15b7 swap.Idle hunt.Help!!
Check for a disconnected vacuum hose and an intake air leak.
Clean and adjust the FITV.
Bleed the cooling system.
Old Nov 15, 2010 | 08:35 AM
cjw_89's Avatar
I will check the vacumm hoses now and bleed the system/top it up.Im frightened to death i will start twisting off bolts on the fitv then im fu*ked.So that will be my last resort.Quick question if i was to have a leaky tb to im gasket what would occour??
thanks for the feedback btw
Old Nov 15, 2010 | 08:47 AM
jose12889's Avatar
on the tb there are 2 holes on the bottom one put ur finger to cover it see wat happens if this the pro cover it and elimate the fast iddle but first is first have u messed with the tps
Old Nov 15, 2010 | 12:39 PM
cjw_89's Avatar
I've done a bit of reasearch,turns out the tb's are pretty much completly different.The diameter where the intake goes on over is way smaller on a d and the ports are in different positions causing my car to have a bad vaccum leak.I checked the fitv earlier today when the car was surging with no difference.Then i decided to put my finger over the tb port.The car idled right down to id say 6-700(estimate) no tach.Im not completly sure but by doing that isnt your car supposed to like shut off,given you have the correct tb on the car.I am going to pic up the right tb and gasket the week and see hwat happens.
condor22
Jan 26, 2019 04:31 PM
eglized
Jul 8, 2009 02:30 PM
rice a roni
Mar 15, 2007 09:47 AM
ludacole
Aug 29, 2004 03:38 PM
GapxGuy
May 11, 2004 02:25 PM
